Started encountering a new problem with CloudXR. Instead of instantly connecting to a machine via Meta Quest, it will hang on the black screen or loading circle for anywhere between 3 and 15 minutes, then all of the sudden it will connect. The log doesn’t give any useful data… just that it was unable to establish a connection, then all of the sudden it was. Any thoughts on what could be causing this would be much appreciated.
that sounds awfully strange, multiple watchdogs should kick in and drop the connection after maybe 20-30s.
Would need to see client and server logs of a run, maybe they give a hint what’s happening under the hood.
