Has anyone experienced any faults from forcing the CPU to perform at high frequencies for prolonged periods of time? I would like to know how rough this board can be treated and how careful I need to be when leaving it running in a high power draw state for prolonged periods of time (4+ hours)
The fan is in place and I haven’t swapped it out for a heat spreader or heat sink and so far the temperatures seem to be reasonable (rarely exceeding 40 deg C)
I also do a lot of single core processing (i.e maxing out CPU0 and leaving the others offline). Is this inadvisable/should I try and spread the load over more cores or let each take turns at being maxed out?
