Hi guys, I’m working on compiling mxnet-1.6 python whl for jetson in jetpack 4.4 DP, base on mxnet docker compile method for previous jetpack version, here is jetson dockerfile.
I want to replace the basic docker image(nvidia/cuda:10.2-cudnn8-devel-ubuntu18.04), and replace all of the jetson deb file mentioned in the dockerfile, for example, cuda-repo-ubuntu1804-10-0-local-10.0.326-410.108_1.0-1_amd64.deb
and cuda-repo-cross-aarch64-10-0-local-10.0.326_1.0-1_all.deb
, to cuda 10.2 version.
I downloaded all the jetson deb file via Nvidia SDK manager, found cuda-repo-l4t-10-2-local-10.2.89_1.0-1_arm64.deb
, but cuda-repo-cross-aarch64-10-2-xxxx.deb
is missing, where can I find this deb file?
Here’s deb file list that SDK manager can provide:
deepstream-5.0_5.0.0-1_arm64.deb
graphsurgeon-tf_7.1.0-1+cuda10.2_arm64.deb
Jetson-210_Linux_R32.4.2_aarch64.tbz2
libcudnn8_8.0.0.145-1+cuda10.2_arm64.deb
libcudnn8-dev_8.0.0.145-1+cuda10.2_arm64.deb
libcudnn8-doc_8.0.0.145-1+cuda10.2_arm64.deb
libnvidia-container0_0.9.0_beta.1_arm64.deb
libnvidia-container-tools_0.9.0_beta.1_arm64.deb
libnvinfer7_7.1.0-1+cuda10.2_arm64.deb
libnvinfer-bin_7.1.0-1+cuda10.2_arm64.deb
libnvinfer-dev_7.1.0-1+cuda10.2_arm64.deb
libnvinfer-doc_7.1.0-1+cuda10.2_all.deb
libnvinfer-plugin7_7.1.0-1+cuda10.2_arm64.deb
libnvinfer-plugin-dev_7.1.0-1+cuda10.2_arm64.deb
libnvinfer-samples_7.1.0-1+cuda10.2_all.deb
libnvonnxparsers7_7.1.0-1+cuda10.2_arm64.deb
libnvonnxparsers-dev_7.1.0-1+cuda10.2_arm64.deb
libnvparsers7_7.1.0-1+cuda10.2_arm64.deb
libnvparsers-dev_7.1.0-1+cuda10.2_arm64.deb
libvisionworks-repo_1.6.0.501_arm64.deb
libvisionworks-sfm-repo_0.90.4.501_arm64.deb
libvisionworks-tracking-repo_0.88.2.501_arm64.deb
nvidia-container-csv-cuda_10.2.89-1_arm64.deb
nvidia-container-csv-cudnn_8.0.0.145-1+cuda10.2_arm64.deb
nvidia-container-csv-tensorrt_7.1.0.16-1+cuda10.2_arm64.deb
nvidia-container-csv-visionworks_1.6.0.501_arm64.deb
nvidia-container-runtime_3.1.0-1_arm64.deb
nvidia-container-toolkit_1.0.1-1_arm64.deb
nvidia-docker2_2.2.0-1_all.deb
nvidia-l4t-jetson-multimedia-api_32.4.2-20200408182156_arm64.deb
OpenCV-4.1.1-2-gd5a58aa75-aarch64-dev.deb
OpenCV-4.1.1-2-gd5a58aa75-aarch64-libs.deb
OpenCV-4.1.1-2-gd5a58aa75-aarch64-licenses.deb
OpenCV-4.1.1-2-gd5a58aa75-aarch64-python.deb
OpenCV-4.1.1-2-gd5a58aa75-aarch64-samples.deb
python3-libnvinfer_7.1.0-1+cuda10.2_arm64.deb
python3-libnvinfer-dev_7.1.0-1+cuda10.2_arm64.deb
python-libnvinfer_7.1.0-1+cuda10.2_arm64.deb
python-libnvinfer-dev_7.1.0-1+cuda10.2_arm64.deb
sdkml3_jetpack_l4t_44_dp_deepstream.json
sdkml3_jetpack_l4t_44_dp.json
Tegra_Linux_Sample-Root-Filesystem_R32.4.2_aarch64.tbz2
uff-converter-tf_7.1.0-1+cuda10.2_arm64.deb
vpi-dev-0.2.0-cuda10-aarch64-l4t.deb
vpi-lib-0.2.0-cuda10-aarch64-l4t.deb
vpi-samples-0.2.0-cuda10-aarch64-l4t.deb
And I post the same issue to mxnet github repo: Need cuda 10.2 python prebuild wheel for nvidia jetson platform
Thanks everyone.
