Looking or help with TensorRT for Agent Studio
I’m trying to install the new Agent Studio. However I’m getting the error:
ImportError: libnvdla_compiler.so: cannot open shared object file: No such file or directory
It sounds like libnvdla_compiler.so is part of TensorRT?
I use a custom carrier board, not devkit, so I cannot use SDK Manager to push these libraries onto the device. Do I have to install TensorRT manually? Does that need CUDA installed also?
You can find the deb package below:
For example:
nvidia-l4t-dla-compiler_36.3.1-20240516220919_arm64.deb
Thanks- from [Index] I downloaded it and run it on the Jetson and it solved the “libnvdla_compiler.so: cannot open shared object file” error
