Hi Mat,
Here’s the code which shows this glitch. The code is a copy-paste of relevant parts of the real code, and this snipped is not supposed to run – the allocatable arrays are not allocated, variables declared but not initialized etc.
I’m compiling it with
pgf90 -Mfree -fastsse -Minfo=all -Minline=level:2 loopnotectorized.f -lacml
and the compilation log says:
MAIN:
31, Loop not vectorized: mixed data types
33, greenfun inlined, size=3, file loopnotectorized.f (42)
47, greenfun_2 inlined, size=23, file loopnotectorized.f (56)
greenfun:
The loop in question is marked with a comment !@#$%
implicit none
! globals
real*8, allocatable :: m_v2(:,:)
integer :: pm,lda ! actual size & leading dimension
real*8, allocatable :: GR_DAT_2(:,:,:), GRD_DAT_2(:,:,:) ! cf ine TABU_2
real*8 :: beta ! inverse temperature
integer :: ntab ! Actual Number of sites per dimension for tabulation
integer :: mtau
real*8 :: bmt, bmt1 ! a shorthand for beta/mtau, and its inverse
! from teh lattice module
integer :: Nsite, Ncell ! # of sites, # of unit cells
integer, allocatable :: ksite(:) ! ksite(name) => site of a kink 'name'
real*8, allocatable :: ktau(:) ! ktau(name) => tau of a kink 'name'
integer, allocatable :: nm_row(:),nm_clmn(:) ! nm_row(row) => name of the kink associated with the row
! from add_2_same
integer :: site,j,nk,vova,sv
real*8 :: tnew, tv, tnew2
lda=128;
allocate(m_v2(lda,2))
do j=1,pm ; vova = nm_clmn(j)
sv = ksite(vova); tv = ktau(vova)
m_v2(j,1) = GREENFUN(sv,tv,site,tnew2)
enddo
contains
! Green Function, selector
real*8 function GREENFUN(site1,tau1,site2,tau2)
implicit none
integer, intent(in) :: site1, site2
real*8, intent(in) :: tau1, tau2
GREENFUN = GREENFUN_2(site1,tau1,site2,tau2)
! GREENFUN = GREENFUN_1(site1,tau1,site2,tau2)
end function GREENFUN
!--- Green Function, spline interpolation of GR_DAT_2
real*8 function GREENFUN_2(site1,tau1,site2,tau2)
implicit none
integer :: site1,site2,j, sgn
real*8 :: tau, tau1, tau2, dt, gre
integer :: nx, ny, nz, nta !, ntb
real*8 :: tta,ttb,ga,gb,c, gra,grb !,p
! prepare \tau
tau=tau1-tau2
dt=tau; sgn=1
if(tau < 1.d-14)then; dt=beta+tau; sgn=-1; endif
! Explanation: G(t=0) must be understood as G(t-> -0) = -G(t=\beta)
! A long way to accomplish this is below, commented out. A short way is above :).
!----------------------------------- spline
nta=dt*bmt1 !*p
tta=dt-nta*bmt
ttb=tta - bmt !dt-ntb*(beta/mtau)
!cccccccccccccccccccccccccccccccccccccc
ga=GR_DAT_2(nta,site1,site2)
gb=GR_DAT_2(nta+1,site1,site2)
gra=GRD_DAT_2(nta,site1,site2)
grb=GRD_DAT_2(nta+1,site1,site2)
c=(ga-gb)*bmt1
gre=(c+gra)*ttb + (c+grb)*tta
gre=gre*tta*ttb*bmt1 + gb*tta-ga*ttb
gre=gre*bmt1
GREENFUN_2 = gre*sgn
end function GREENFUN_2
! Tabulates Green function and its time derivate at positive tau : ALL-NUMERICAL,
! taken from ../disord/fermi-hubbard-disord.f
subroutine TABU_2
implicit none
real*8, allocatable :: ham(:,:)
integer :: site,site1,j
real*8 :: factor, ww,ttt,term, gamma, expet(0:mtau)
integer :: nt
! lapack stuff
character*1 :: jobz,uplo
integer :: ldh, lwork,info
real*8, allocatable :: work(:), eps(:)
integer :: site2, i_x1(3), i_x2(3), n1,n2
print*,' TABU_2'
if(allocated(GR_DAT_2)) deallocate(GR_DAT_2)
if(allocated(GRD_DAT_2)) deallocate(GRD_DAT_2)
allocate( GR_DAT_2(0:mtau+1,1:Nsite,1:Nsite), GRD_DAT_2(0:mtau+1,1:Nsite,1:Nsite) )
! build the hamiltonian
allocate(ham(1:Nsite,1:Nsite)) ;
ham=0.d0
!------------------------------- commented out for the loopnotectorized ONLY
! do site=1,Nsite
! do j=1,coord_nbr(site); site1=neighb(j,site);
! ham(site,site1)=ham(site,site1)-hop_int(j,site)
! enddo
! if(site_layer(site)==1)then; ham(site,site) = -Vlayer
! else; ham(site,site) = Vlayer
! endif
! enddo;
! compute eigenvalues; for LAPACK parameters and arguments, see
! http://www.netlib.org/lapack/double/dsyev.f
! SUBROUTINE DSYEV( JOBZ, UPLO, N, A, LDA, W, WORK, LWORK, INFO )
jobz='V' ! compute eigenvectorz
uplo='U' ! use upper diag of ham(:,:) --- doesn't matter really
ldh=Nsite
lwork=12*Nsite
allocate( work(lwork), eps(Nsite) )
! query the optimal workspace size
call dsyev(jobz,uplo,Nsite,ham,ldh,eps,work,-1,info)
lwork=work(1)
deallocate(work); allocate(work(lwork))
! diagonalize
call dsyev(jobz,uplo,Nsite,ham,ldh,eps,work,lwork,info)
if(info/=0)then; print*,'*** dsyev returns info = ', info
print*,'*** check the TABULATE routine'
call mystop
endif
!------------- have the spectrum, proceed to the GFs
GR_DAT_2=0.d0; GRD_DAT_2=0.d0
do j=1,Nsite
gamma=-eps(j)*beta
gamma=exp(gamma)+1.d0
gamma=-1.d0/gamma
ww = exp(-eps(j)*bmt) ! bmt=beta/mtau
do nt=0,mtau; expet(nt)=ww**nt
enddo
do site=1,Nsite ; do site1=1,Nsite
factor = ham(site,j)*ham(site1,j)
do nt=0,mtau
term = factor*expet(nt)*gamma !/Nsite
GR_DAT_2(nt,site,site1) = GR_DAT_2(nt,site,site1) + term
GRD_DAT_2(nt,site,site1) = GRD_DAT_2(nt,site,site1) -eps(j)*term
enddo
enddo; enddo ! site, site1
enddo ! j: eigenvalues
! fill in fictitious nt=mtau+1, see GREENFUN for explanation
GR_DAT_2(mtau+1,:,:)=0.d0; GRD_DAT_2(mtau+1,:,:)=0.d0
end subroutine TABU_2
subroutine mystop
!!! free the memory etc
stop
end subroutine mystop
end
Do you spot anything suspicious?
Thanks,
Zhenya
