I am trying to loop a video using the example code and gstreamer:
class SomeClass(object):
def video_call(self):
GObject.threads_init()
Gst.init(None)
self.playbin = Gst.ElementaryFactory.make("playbin", None)
uri = Gst.filename_to_uri("CES_AE_3D.mp4")
self.playbin.set_property('uri', uri)
self.loop = GObject.MainLoop()
bus = self.playbin.get_bus()
bus.add_signal_watch()
bus.connect("message", self.bus_call, self.loop)
self.playbin.set_state(Gst.State.PLAYING)
try:
self.loop.run()
except:
pass
set.playbin_set_state(Gst.State.NULL)
def loop_control(self):
while True:
if condition_var:
self.video_call()
This is a simplified version of the code, with bus_call method as well. And everything works fine, but then after 5 minutes I get an error along the lines of:
Any solutions would be helpful.
For information, please share release version:
$ head -1 /etc/nv_tegra_release
And share what elements are used in playbin by setting:
$ export GST_DEBUG=*FACTORY*:4
I am getting same error “Too many open files” on jetson nano.
For me the output of $ head -1 /etc/nv_tegra_release is
R32 (release), REVISION: 3.1, GCID: 18186506, BOARD: t210ref, EABI: aarch64, DATE: Tue Dec 10 06:58:34 UTC 2019
And by setting: $ export GST_DEBUG=FACTORY:4, I get output of my code as
0:00:31.702954726 12024 0x202d2680 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “udpsrc”
I am reading rtsp stream using below function
def open_cam_rtsp(uri, width, height, latency):
gst_str = ('rtspsrc location={} latency={} ! ’
'rtph264depay ! h264parse ! omxh264dec ! ’
'nvvidconv ! ’
'video/x-raw, width=(int){}, height=(int){}, ’
'format=(string)BGRx ! ’
‘videoconvert ! appsink’).format(uri, latency, width, height)
return cv2.VideoCapture(gst_str, cv2.CAP_GSTREAMER)
Any suggestions how to get rid of this “Too many open files” error?
We are deprecating omx plugins. Please try nvv4l2decoder. You can refer to C samples(opencv_gst_samples_src.tbz2) in
https://developer.nvidia.com/embedded/L4T/r32_Release_v4.2/Sources/T210/public_sources.tbz2
Thank you, removing omxh worked for me.
