loosing memory, not knowing how
I have a -small?- issue with one of my own made programs.
I do not know how I am loosing memory, where it goes? That is a mystery…
It seems like one of my frees instructions is not working as it is suppose to.
The code does something like this:
[codebox]
cudaArray* cuArrayTarget = 0;
cudaArray* cuArrayReference = 0;
cudaMallocArray(&cuArrayReference, &channelDesc, width, height);
cudaMemcpyToArray(cuArrayReference, 0, 0, refImage, widthheightsizeof(float), cudaMemcpyHostToDevice);
cudaBindTextureToArray(textReference, cuArrayReference, channelDesc);
cudaMallocArray(&cuArrayTarget, &channelDesc, width, height);
cudaMemcpyToArray(cuArrayTarget, 0, 0, refImage, widthheightsizeof(float), cudaMemcpyHostToDevice);
cudaBindTextureToArray(textTarget, cuArrayTarget, channelDesc);
int* v1;
int* v2;
cudaMalloc((void**)&v1, s1*sizeof(int));
cudaMalloc((void**)&v2, s2*sizeof(int));
kernel …
int* output = (int*)malloc( v3*sizeof(int) );
cudaMemcpy(output, v1, v3*sizeof(int), cudaMemcpyDeviceToHost);
cudaUnbindTexture(textReference);
cudaUnbindTexture(textTarget);
cudaFree(values);
cudaFree(vectors);
cudaFreeArray(cuArrayReference);
cudaFreeArray(cuArrayTarget);
free(output);
[/codebox]
As you can see I do create 2 cudaArrays, allocate 2 arrays, update 2 textures, copy back the info.
There are no errors on the cudaFree or cudaUnbinds (the CUDA_SAFE_CALL has been removed to make the code more looking-friendly).
Any idea where my leak can be?
you also allocate:
int* v1;
int* v2;
cudaMalloc((void**)&v1, s1sizeof(int));
sizeof(int));
and you forget to free them, probably you try to free them by:
cudaFree(values);
cudaFree(vectors);
However then you allocate you use v1 and v2.
Happy coding!
