I’m going through the “DLI Getting Started with AI on Jetson Nano”.
I can access the sample code and notebooks no problem over SSH and in my browser.
However, if I create a new Jupyter notebook and save it, and then restart the docker (or restart the device), all my saved notebooks are gone.
Any images I save using the tools are still on the device in the data folder.
Please help.
Hi @jdeglint, you would need to save your notebook (or other files you wanted to be persistent after shutting down the container) to a mounted directory - the data folder is mounted to the host.
You can see that data folder mounted with the --volume
option in the command-line used to start the container:
sudo docker run --runtime nvidia -it --rm --network host \
--volume ~/nvdli-data:/nvdli-nano/data \
--device /dev/video0 \
nvcr.io/nvidia/dli/dli-nano-ai:<tag>
You can create another directory on your device (outside of container) and mount it the same way (by specifying another --volume HOST_DIR:CONTAINER_DIR
option). Or you can just use the existing data dir that’s already mounted.
Thanks for the quick reply!
Okay great. That makes sense.
I’m new to docker so I appreciate your help.
