Low accuracy for analytics line crossing (Falce negative)
• Hardware Platform (Jetson / GPU) NVIDIA GeForce RTX 4070
• DeepStream Version 7.0
• TensorRT Version 8.6.1.6-1+cuda12.0
• NVIDIA GPU Driver Version (valid for GPU only) 535.216.01
Im using deepstream analytics Python app with Detectnet_v2 retrained in my custom data. The line crossing is missing many crossing objects. Please, see the result below:
Here are the input video and the configurations:
config_nvdsanalytics.txt (2.7 KB)
Thanks for the sharing! noticing some cars are not detected, could you highlight which cars are not coutned by line corssing?
@fanzh, thank you for replying!
To be more specific, I have noticed that the application fail to count cars that have slow velocity. The last video that I uploaded, the application fail all count. Unfortunately a can not upload a video with more than 100mbytes.
How can I upload my model (.engine) so that you can reproduce the error?
In the first video above, At which second and which cars(you can point the carid) are not counted? you may split the file to multiple files by zip.
Here, car ID 7 and 9 are not counted.
In the first video, car ID 9 (0:10 second) and car ID 7 (0:15 second) not count.
Here is the model that Im using:
resnet18_detector.onnx_b1_gpu0_fp16.zip (19.5 MB)
which deepstream sample are you testing or referrng to? what is the whole media pipeline?
noticing you are testng a hight resoluton video, the resnet18_detector.onnx_b1_gpu0_fp16.zip you shared is a TRT engine file, which is is hardware dependent, to reprodcue this issue, could you share the onnx model and configuration file?
The problem was the streammux size:
streammux.set_property(‘width’, 856)
streammux.set_property(‘height’, 480).
When I changed to:
streammux.set_property(‘width’, 2720)
streammux.set_property(‘height’, 1530)
The problem was solved. Now all line crossing are counting.
