I’m trying a very simple setup connecting a ConnectX-3 card on one host directly to another ConnectX-3 card on another. I’m using DPDK 2.2 and pktgen-2.9.7 to send packets from one to another. I have configured both sending and receiving ports to Ethernet.
Things are functional, I can saturate 40Gb/s with packet sizes of 1024 or 512 bytes but not with 256 bytes or lower. Seems like the max throughput I get is 12 Mpps.
I verified that I have set log_num_mgm_entry_size=-7.
This is my pktgen command line: pktgen -c 0xFFF00 -n 4 -w 0000:82:00.0 -m 2048 – -T -P -p 0x0 -m “[10-11:12-13].0”
Any idea why I can’t saturate the line with small packets? Any help would be greatly appreciated.
Thanks for your comments. Burst size is set to 32 by default, at least when I try it on 82599 or ConnectX-3. And it can be modified using "set <port#> burst " command in pktgen. Pktgen doesn’t accept a value larger than 32 for the burst size (unless I recompile the source code obviously as you mentioned). However, regardless of whether I set the burst size to 1 or 32, I still get the same ~12 Mpps.
