Low FPS on transfer learning model
I am getting really really low fps. in camera and also in video files. The code and fps value are below:
from json import detect_encoding
from cv2 import detail_ProjectorBase
import jetson.inference
import jetson.utils
import time
import cv2
import numpy as np
import RPi.GPIO as GPIO
import time
#!/usr/bin/env python
print("Successfully installed all libraries")
# for 1st Motor on ENA
ENA = 33
IN1 = 35
IN2 = 36
# FOR 2ND MOTOR ON ENB
ENB = 32
IN3 = 37
IN4 = 38
# set pin numbers to the board's
GPIO.setmode(GPIO.BOARD)
# initialize EnA, In1 and In2
GPIO.setup(ENA, GPIO.OUT, initial=GPIO.LOW)
GPIO.setup(IN1, GPIO.OUT, initial=GPIO.LOW)
GPIO.setup(IN2, GPIO.OUT, initial=GPIO.LOW)
GPIO.setup(ENB, GPIO.OUT, initial=GPIO.LOW)
GPIO.setup(IN3, GPIO.OUT, initial=GPIO.LOW)
GPIO.setup(IN4, GPIO.OUT, initial=GPIO.LOW)
# Stop
GPIO.output(ENA, GPIO.HIGH)
GPIO.output(IN1, GPIO.LOW)
GPIO.output(IN2, GPIO.LOW)
GPIO.output(ENB, GPIO.HIGH)
GPIO.output(IN3, GPIO.LOW)
GPIO.output(IN4, GPIO.LOW)
time.sleep(1)
# # Stop
# GPIO.output(IN1, GPIO.LOW)
# GPIO.output(IN2, GPIO.LOW)
# GPIO.output(IN3, GPIO.LOW)
# GPIO.output(IN4, GPIO.LOW)
# time.sleep(1)
# # Backward
# GPIO.output(IN2, GPIO.HIGH)
# GPIO.output(IN4, GPIO.HIGH)
# time.sleep(1)
def distance_between_bounding_boxes(box1, box2):
    center1_x = (box1[0] + box1[2]) / 2
    center1_y = (box1[1] + box1[3]) / 2
    center2_x = (box2[0] + box2[2]) / 2
    center2_y = (box2[1] + box2[3]) / 2
    return int(((center1_x - center2_x) ** 2 + (center1_y - center2_y) ** 2) ** 0.5)
timeStamp=time.time()
fpsFilt=0
net=jetson.inference.detectNet(argv=['--model=/home/nano/jetson-inference/python/training/detection/ssd/models/model0110/ssd-mobilenet.onnx',
                                    '--labels=/home/nano/jetson-inference/python/training/detection/ssd/models/model0110/labels.txt',
                                    '--input_blob=input_0', '--output_cvg=scores', '--output_bbox=boxes'],threshold=0.6)
dispW=800
dispH=600
flip=2
font=cv2.FONT_HERSHEY_SIMPLEX
# Gstreamer code for improvded Raspberry Pi Camera Quality
#camSet='nvarguscamerasrc wbmode=3 tnr-mode=2 tnr-strength=1 ee-mode=2 ee-strength=1 ! video/x-raw(memory:NVMM), width=3264, height=2464, format=NV12, framerate=21/1 ! nvvidconv flip-method='+str(flip)+' ! video/x-raw, width='+str(dispW)+', height='+str(dispH)+', format=BGRx ! videoconvert ! video/x-raw, format=BGR ! videobalance contrast=1.5 brightness=-.2 saturation=1.2 ! appsink'
#cam=cv2.VideoCapture(camSet)
#cam=jetson.utils.gstCamera(dispW,dispH,'0')
input_video = "test.mp4"
cam=cv2.VideoCapture(input_video)
cam.set(cv2.CAP_PROP_FRAME_WIDTH, dispW)
cam.set(cv2.CAP_PROP_FRAME_HEIGHT, dispH)
print("Input video loaded")
#cam=jetson.utils.gstCamera(dispW,dispH,'/dev/video1')
#display=jetson.utils.glDisplay()
#while display.IsOpen():
while True:
    #img, width, height= cam.CaptureRGBA()
    _,img = cam.read()
    height=img.shape[0]
    width=img.shape[1]
    frame=cv2.cvtColor(img,cv2.COLOR_BGR2RGBA).astype(np.float32)
    frame=jetson.utils.cudaFromNumpy(frame)
    detections=net.Detect(frame, width, height)
    for detect in detections:
        #print(detect)
        print("detect")
        ID=detect.ClassID
        item=net.GetClassDesc(ID)
        #if item='plant'
        top=int(detect.Top)
        left=int(detect.Left)
        bottom=int(detect.Bottom)
        right=int(detect.Right)
        width = int(detect.Width)
        height = int(detect.Height)
        box1 = (left, top, left + width, top + height)
        print(item,top,left,bottom,right)
        cv2.rectangle(img,(left,top),(right,bottom),(0,255,0),1)
        cv2.putText(img,item,(left,top+20),font,.75,(0,0,255),2)
        # algorithm 1 starts for calculating distance between 2 bounding boxes
        previous_distance = None
        for i in range(len(detections)):
            left1 = detections[i].Left
            top1 = detections[i].Top
            width1 = detections[i].Width
            height1 = detections[i].Height
            box1 = (left1, top1, left1 + width1, top1 + height1)
            if i == 0:
                left2 = detections[i + 1].Left
                top2 = detections[i + 1].Top
                width2 = detections[i + 1].Width
                height2 = detections[i + 1].Height
                box2 = (left2, top2, left2 + width2, top2 + height2)
                distance = distance_between_bounding_boxes(box1, box2)
                print("Distance: ", distance)
                if previous_distance != distance:
                    #previous_distance = distance
                    print("Distance between bounding box", i+1, "and bounding box", i+2, "is: ", distance)
                    if distance>=100:
                        # Forward
                        GPIO.output(IN1, GPIO.HIGH)
                        GPIO.output(IN3, GPIO.HIGH)
                        time.sleep(1)
                    else:
                        # Stop
                        GPIO.output(ENA, GPIO.LOW)
                        GPIO.output(ENB, GPIO.LOW)
                        time.sleep(1)
        # algorithm 1 ends for calculating distance between 2 bounding boxes
    #display.RenderOnce(img,width,height)
    dt=time.time()-timeStamp
    fps=1/dt
    fpsFilt=.9*fpsFilt + .1*fps
    #print(str(round(fps,1))+' fps')
    cv2.putText(img,str(round(fpsFilt,1))+' fps',(0,30),font,1,(0,0,255),2)
    cv2.imshow('detCam',img)
    cv2.moveWindow('detCam',0,0)
    if cv2.waitKey(1)==ord('q'):
        break
cam.release()
GPIO.cleanup()
cv2.destroyAllWindows()
![WhatsApp Image 2023-01-17 at 11.53.01 PM|666x500](upload://zUFotZbtOq9zJoaZeGqetxpY1pa.jpeg)
i commented out the GPIO lines and i am getting 13-15 fps. What might be the problem?
Hi @adnan.f.a, how many classes does your model have?
What performance do you get if you run detectnet.py like this:
detectnet.py --model=/home/nano/jetson-inference/python/training/detection/ssd/models/model0110/ssd-mobilenet.onnx --labels=/home/nano/jetson-inference/python/training/detection/ssd/models/model0110/labels.txt --input_blob=input_0 --output_cvg=scores --output_bbox=boxes test.mp4
Or you can run your ONNX model through trtexec and compare the performance of the model itself. My first guess is that it’s related to the OpenCV functions.
My model has only one label. When running through detectnet.py then the fps seems okay. But when using it in my python program i am facing this issue. Is there any guideline for running the onnx model on trtexec?
You would run trtexec like trtexec --onnx=PATH_TO_YOUR_MODEL (trtexec is found under /usr/src/tensorrt/bin), but since detectnet.py is fine, I don’t think the model is the issue. I think it is the various calls to cv2 module that are slowing it down, those are CPU-based.
