Hi
I’m using OpenACC-Fortran (PGI-Compiler 15.4) with nvidia on windows.
The utility “nvidia-smi.exe” shows quite low load-rate of the GPU. (About 27% in the example.)
| NVIDIA-SMI 340.66 Driver Version: 340.66 |
| GPU Name TCC/WDDM | Bus-Id Disp.A | Volatile Uncorr. ECC |
| 0 Quadro K2000 TCC | 0000:0A:00.0 Off | N/A |
| 30% 40C P0 N/A / N/A | 60MiB / 2047MiB | 27% Default |
| Compute processes: GPU Memory |
| GPU PID Process name Usage |
| 0 8044 ..._trunk\builds\de\pgi\release\myprog.exe 53MiB |
Which tools shall I use to measure, why this load is so low?
I tried pgcollect as a pgprof-preprocessor. But I get an error message “pgi-prof-win32: LICENSE MANAGER PROBLEM: License server does not support this feature.”
Benedikt
