• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 6.1
• TensorRT Version 8.4.2.4
• NVIDIA GPU Driver Version 510.47.03
• Issue Type questions or bugs
I set pgie to “interval=0”, I detect more frame outputs.
I set pgie to “interval=5”, I detect less frame outputs.
However, “interval=5” mode has some frame outputs, “interval=0” can’t detect that. It means “interval=0” will cause loss frames?
I already checked my computer gpu usage and cpu usage and memory is all ok. What causes that?
My code is from deepstream-appsrc-test.
This reason is from appsrc pipeline? How to fix that?
Do you mean some objects are missed with “interval=0”?
These is example.
Or
“interval=5” Output =>
car1
car1
car2
car2
car3
car3
car4
car4
“interval=0” Output =>
car1
car1
car1
car1
car2
car2
car2
car2
car4
car4
car4
car4
Actually there is only confidence print out in your code. I’m confused with your description. Can you send the correct code?
Okay, I already sent a message to you.
I think maybe the speed of my computer can’t support high framerate.
deepstream-app : drop-frame-interval <== do you know how do I add to “deepstream-appsrc-test”?
Because I know “interval” doesn’t match my need. it still run full fps, just inferece a part of those.
