I cannot comment on argus, but if gstreamer works fine for you, you may build the pipeline in your application so that you can perform your own processing (assuming with GPU in NVMM memory). See this opencv example (Not sure it was a good idea to use sobel on alpha channel, though, BGR should be enough).
You would adapt to your own case.
