cdevd
June 14, 2021, 1:11pm
1
Xavier agx dev kit
jetpack 4.3
deepstream4.02
How do I lower detector confidence threshold to increase the number of boxes and detections?
In the primary-gie config file have tried:
threshold=0.1
classifier-threshold=0.1
but it doesn’t seem to be any different to when they are =0.9
Is there somewhere else where the detection level can be set?
bcao
June 17, 2021, 10:38am
3
There is a threshold for detectors pre-cluster-threshold
cdevd
June 18, 2021, 10:44am
4
thanks bcao,
I only seem to be able to change the threshold for my detectnet model not my yolo models?
do I need to do something different with yolo models?
I’m using YoloV3Tiny
Update:
I think I need to change threshold parameters in nvdsinfer_custom_impl_Yolo/nvdsparsebbox_Yolo.cpp.
static bool NvDsInferParseYoloV3(
const uint kNUM_BBOXES = 3;
static const float kNMS_THRESH = 0.3f;
static const float kPROB_THRESH = 0.7f;
I think these values are shared V3 and V3Tiny?
Can you tell me what kNMS_THRESH and kPROB_THRESH mean individually? what each one does?
I assume I need to create a new libnvdsinfer_custom_impl_Yolo.so file every time I want to adjust the sensitivity?
bcao
June 22, 2021, 9:54am
5
Do you mean the pre-cluster-threshold not work for yolo?
system
Closed
September 4, 2021, 3:04am
7
