I’m currently training LPRNet as part of my bachelor’s. I have a dataset of about 500 license plate photos which I have expanded in pre-processing by adding rotation, blurring, shearing etc. As per my bachelor’s I have to use Romanian license plates. Here are a few examples:
Imgur: The magic of the Internet (can’t create more than one media attachment as a new user, sorry)
I have tried training the model using exclusively the base augmented dataset without adding any synthetic license plates. After augmentation and adding synth plates I have 15k images in an 80/20 train/validation split. At epoch 535 I got my first 80% accuracy. At this point I’m thinking the model is already overfitted but I was aiming for 90% accuracy.
{“epoch”: 530, “max_epoch”: 575, “time_per_epoch”: “0:01:10.170579”, “eta”: “0:52:37.676053”, “date”: “7/3/2025”, “time”: “17:11:31”, “status”: “RUNNING”, “verbosity”: “INFO”, “message”: “Training loop in progress”, “graphical”: {“loss”: “0.56262165”, “learning_rate”: “0.0010627531”, “accuracy”: “0.8195”}, “kpi”: {“accuracy”: “0.8195”}}
This is my current config after tweaking it around and trying multiple datasets (with or without synth, 10k instead of 15k etc.)
random_seed: 42
lpr_config {
hidden_units: 512
max_label_length: 7
arch: “baseline”
nlayers: 10
training_config {
batch_size_per_gpu: 128
num_epochs: 350
learning_rate {
soft_start_annealing_schedule {
min_learning_rate: 8e-5
max_learning_rate: 2e-3
soft_start: 0.1
annealing: 0.7
regularizer {
type: L2
weight: 1e-5
eval_config {
validation_period_during_training: 5
batch_size: 1
augmentation_config {
output_width: 96
output_height: 48
output_channel: 3
max_rotate_degree: 3
rotate_prob: 0.4
gaussian_kernel_size: 3
gaussian_kernel_size: 5
blur_prob: 0.3
reverse_color_prob: 0.1
keep_original_prob: 0.5
dataset_config {
data_sources: {
label_directory_path: “/workspace/tao-experiments/Dataset_02/train/labels”
image_directory_path: “/workspace/tao-experiments/Dataset_02/train/images”
characters_list_file: “/workspace/tao-experiments/characters_list.txt”
validation_data_sources: {
label_directory_path: “/workspace/tao-experiments/Dataset_02/val/labels”
image_directory_path: “/workspace/tao-experiments/Dataset_02/val/images”
My specs are as follows: RTX 3070 Laptop Edition 8GB VRAM, 64GB system RAM I’m running TAO on WSL2. I installed TAO using the old guide. Making a conda virtual env installing all the prereqs etc.
My main problem is that when running inference on my 82% accuracy model it fails to correctly predict even one license plate out of a sample of 40. It gets close on many e.g AR10MSE predicts it as AR0MSE, or IS16LWZ is predicted as either IS15WZ or IS16WZ. Now my main question is, can I continue trying to train with maybe a different spec file with some changes. Or should I keep my dataset and start from scratch using the notebook version of LPRNet? If you think I can continue like this I’d like some pointers for the spec file since I’m pretty stumped.
Also really important: do output_width and output_height have to be exactly the resolution of the input images?
