• Hardware: any
• Network Type: LPRNet
• Tao Version: 4.0.0, format version: 2.0
• Training spec file:
[property]
gpu-id=0
force-implicit-batch-dim=0
tlt-encoded-model=/lpr.etlt
model-engine-file=/lpr.etlt_b32_gpu0_fp16.engine
labelfile-path=/lpr_labels.txt
tlt-model-key=nvidia_tlt
batch-size=32
scaling-compute-hw=1
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=2
num-detected-classes=3
gie-unique-id=3
output-blob-names=output_bbox/BiasAdd;output_cov/Sigmoid
#0=Detection 1=Classifier 2=Segmentation
network-type=1
parse-classifier-func-name=NvDsInferParseCustomNVPlate
custom-lib-path=/opt/nvidia/deepstream/deepstream-6.1/sources/libs/anpr_layer/libnvdsinfer_custom_impl_lpr.so
process-mode=2
operate-on-gie-id=2
net-scale-factor=0.00392156862745098
#net-scale-factor=1.0
#0=RGB 1=BGR 2=GRAY
model-color-format=0
[class-attrs-all]
threshold=0.5
Deepstream version: 6.1.1
• How to reproduce the issue? (This is for errors. Please share the command line and the detailed log here.)
I want to train and deploy the LPRNet model with Deepstream. There weren’t problems with the previous version of TaoToolkit (I think 3.0.0). The steps were as follows:
- Train the LPRNet model
- Export etlt model
- Put raw etlt model to deepstream models directory
- Compile model to .engine without problems
However, with tao 4.0.0 I can’t compile the model directly inside the deepstream app. Below are logs from compiling the etlt model by deepstream
0:00:00.738115874 7 0x45e3c60 INFO nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger:<secondary-inference-1> NvDsInferContext[UID 3]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1914> [UID = 3]: Trying to create engine from model files
parseModel: Failed to parse ONNX model
ERROR: tlt/tlt_decode.cpp:389 Failed to build network, error in model parsing.
ERROR: ../nvdsinfer/nvdsinfer_model_builder.cpp:723 Failed to create network using custom network creation function
ERROR: ../nvdsinfer/nvdsinfer_model_builder.cpp:789 Failed to get cuda engine from custom library API
va-engine | 0:00:01.110047707 7 0x45e3c60 ERROR nvinfer gstnvinfer.cpp:640:gst_nvinfer_logger:<secondary-inference-1> NvDsInferContext[UID 3]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1934> [UID = 3]: build engine file failed
7 Segmentation fault
I’ve also tried to compile the etlt model by tao toolkit to the .engine file and test. The logs are:
ERROR: [TRT]: 1: [stdArchiveReader.cpp::StdArchiveReader::40] Error Code 1: Serialization (Serialization assertion stdVersionRead == serializationVersion failed.Version tag does not match. Note: Current Version: 205, Serialized Engine Version: 232)
ERROR: [TRT]: 4: [runtime.cpp::deserializeCudaEngine::50] Error Code 4: Internal Error (Engine deserialization failed.)
ERROR: ../nvdsinfer/nvdsinfer_model_builder.cpp:1528 Deserialize engine failed from file: /lpr.etlt_b32_gpu0_fp16.engine
0:00:00.767097152 7 0x410e660 WARN nvinfer gstnvinfer.cpp:643:gst_nvinfer_logger:<secondary-inference-1> NvDsInferContext[UID 3]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1888> [UID = 3]: deserialize engine from file :/lpr.etlt_b32_gpu0_fp16.engine failed
0:00:00.786249154 7 0x410e660 WARN nvinfer gstnvinfer.cpp:643:gst_nvinfer_logger:<secondary-inference-1> NvDsInferContext[UID 3]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1993> [UID = 3]: deserialize backend context from engine from file :/lpr.etlt_b32_gpu0_fp16.engine failed, try rebuild
0:00:00.786266988 7 0x410e660 INFO nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger:<secondary-inference-1> NvDsInferContext[UID 3]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1914> [UID = 3]: Trying to create engine from model files
0:00:01.143307313 7 0x410e660 ERROR nvinfer gstnvinfer.cpp:640:gst_nvinfer_logger:<secondary-inference-1> NvDsInferContext[UID 3]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1934> [UID = 3]: build engine file failed
./start.sh: line 15: 7 Segmentation fault (core dumped) python3 run.py
I’ve attached custom LPR parser (download from github repo)
nvinfer_custom_lpr_parser.cpp (4.6 KB)
Question:
- Is it possible to train LPRNet model with taotoolkit 4.0.0, and export etlt model to deepstream, which compiles it automatically? - I’ve done this successfully with previously trained models also based on tao toolkit
- If not, which version of tao toolkit should I use to export and compile models automatically?
I believe it is possible because it works with one of the previous versions of taotoolkit LPRNet trained model but I don’t know which version I should use - I didn’t find previous versions on the pip repository.
