I tried to convert a lraw data to raw data using the following command:
sudo LD_LIBRARY_PATH=/usr/local/cuda/lib64 ./lraw2raw --inputfile=~/records/cam_bld_120fov.lraw --outputfile=~/records/cam_bld_120fov_ed.raw --usePinnedMemory=0
As it’s stated in the page: NVIDIA Documentation Center | NVIDIA Developer
However, I got the following error:
sudo: ./lraw2raw: command not found
I also checked FAQ in nvidia docs (here: Installation Guide Linux :: CUDA Toolkit Documentation)
It says that
"Your LD_LIBRARY_PATH environment variable is not set up correctly. Ensure that your LD_LIBRARY_PATH includes the lib and/or lib64 directory where you installed the Toolkit, usually /usr/local/cuda-10.2/lib{,64}:"
However my path seems correct. I couldn’t find the solution yet.
Any solution will be appreciated.
