I have an LT6911C board connected to a Jetson Nano module, however when I load up the board it appears to be detected as an IMX219 camera module. How is this detection done and how can we debug why it’s being incorrectly detected?
I’ve confirmed that the driver for the LT6911UXC is loaded correctly and the manufacturer (Lontium) indicated that that driver should be compatible with the LT6911C board. Kernel log attached:
I also noticed that the LT6911UXC doesn’t seem to be added to the device tree, does this need to be done manually? If so, are there any good guides for how to do that? This is my first experience working this close to hardware :)
Did you get the above setup working? I’ve been looking for a driver for the LT6911UXC (on my bridge board B112 from Auvidea) to get it working with the Nano but the only driver I’ve found is for Jetson Xavier AGX - GitHub - InES-HPMM/Lontium_lt6911uxc: Driver for HDMI to CSI converter lt6911uxc is this the one you used and modified to work on Nano?
When I checked with Lontium they kept saying this doesn’t need a driver, but refused to give any confirmation on whether the above Xavier driver should work or not. So when you’ve said Lontium indicated the driver should be compatible - is this what you checked?
This document applies to CSI cameras and has properties relating to the camera such as the sensor size but we’re not sure how to configure that for a board that is exposing an HDMI input?
The device tree configuration is custom to our carrier board. As I mentioned, the quoted example is sufficient to walk through how to create one. We are also not particularly interested in working for free.
