Isaac Sim Version
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
- Driver Version: 535.230.02
Topic Description
Lula Robot Description Editor Could not generate spheres
Detailed Description
Hello, I want to use Lula Robot Description Editor to generate collision spheres for my robot. I have the urdf file, so first I used the urdf importer to get the usd file, and then I tried to use Lula Robot Description Editor to generate spheres for all the links. However, the āgenerate spheresā function didnāt work, and the console output the warning:
[isaacsim.robot_setup.xrdf_editor.extension] Could not generate spheres for any meshes in link /rail_link. This is likely due to all meshes nested under /rail_link being instanceable
I am a starter of isaacsim and Iām confused about the instanceable property. I checked the elements in ārobot_descriptionā, only visuals and collisions of each link are instanceable.
So how can I solve this problem?
Thank you for any support.
Error Messages
2025-05-14 03:13:18 [133,580ms] [Warning] [isaacsim.robot_setup.xrdf_editor.extension] Found instanceable mesh at path /World/robot_description/r_link_4/visuals/r_link_4/mesh. Instanceable meshes are not fully compatible with the Robot Description Editor. They cannot be used to generate spheres automatically. You may author spheres by hand or stop the timeline and uncheck āInstanceableā in the Properties panel for this path and all parent paths.
2025-05-14 03:13:18 [133,580ms] [Warning] [isaacsim.robot_setup.xrdf_editor.extension] Found instanceable mesh at path /World/robot_description/r_link_4/collisions/r_link_4/mesh. Instanceable meshes are not fully compatible with the Robot Description Editor. They cannot be used to generate spheres automatically. You may author spheres by hand or stop the timeline and uncheck āInstanceableā in the Properties panel for this path and all parent paths.
2025-05-14 03:13:18 [133,580ms] [Warning] [isaacsim.robot_setup.xrdf_editor.extension] Found instanceable mesh at path /World/robot_description/r_link_5/visuals/r_link_5/mesh. Instanceable meshes are not fully compatible with the Robot Description Editor. They cannot be used to generate spheres automatically. You may author spheres by hand or stop the timeline and uncheck āInstanceableā in the Properties panel for this path and all parent paths.
2025-05-14 03:13:18 [133,580ms] [Warning] [isaacsim.robot_setup.xrdf_editor.extension] Found instanceable mesh at path /World/robot_description/r_link_5/collisions/r_link_5/mesh. Instanceable meshes are not fully compatible with the Robot Description Editor. They cannot be used to generate spheres automatically. You may author spheres by hand or stop the timeline and uncheck āInstanceableā in the Properties panel for this path and all parent paths.
2025-05-14 03:13:18 [133,581ms] [Warning] [isaacsim.robot_setup.xrdf_editor.extension] Could not generate spheres for any meshes in link /base_link. This is likely due to all meshes nested under /base_link being instanceable
