Lula Test Widget has a error
2024-09-04 07:39:30 [Error] [omni.ui.python] RuntimeError: e[31m[Lula] C:\vc\lula\src\lula\kinematics\urdf_util.cpp:456: error: Failed check (urdf_model): Failed to parse URDF from path ‘E:/USD/mybuddy/urdf/mybuddy.urdf’.
2024-09-04 07:39:30 [Error] [omni.ui.python] e[0me[31m[Lula] C:\vc\lula\src\lula\kinematics\urdf_util.cpp:456: error: Failed check (urdf_model): Failed to parse URDF from path ‘E:/USD/mybuddy/urdf/mybuddy.urdf’.
2024-09-04 07:39:30 [Error] [omni.ui.python] At:
2024-09-04 07:39:30 [Error] [omni.ui.python] e:/issac/ov/isaac-sim-4.0.0/exts/omni.isaac.motion_generation/omni/isaac/motion_generation/lula/kinematics.py(45): init
2024-09-04 07:39:30 [Error] [omni.ui.python] e:/issac/ov/isaac-sim-4.0.0/exts/omni.isaac.lula_test_widget/omni/isaac/lula_test_widget/test_scenarios.py(87): initialize_ik_solver
2024-09-04 07:39:30 [Error] [omni.ui.python] e:/issac/ov/isaac-sim-4.0.0/exts/omni.isaac.lula_test_widget/omni/isaac/lula_test_widget/extension.py(296): _refresh_ee_frame_combobox
2024-09-04 07:39:30 [Error] [omni.ui.python] e:/issac/ov/isaac-sim-4.0.0/exts/omni.isaac.lula_test_widget/omni/isaac/lula_test_widget/extension.py(503): on_load_config
I exported urdf from usd. There was no problem with urdf. Why did such a problem occur?
Could you please try the newly released Isaac Sim 4.2.0 and let us know if you still encounter any problems?
Hi I’m currently getting the same error on 4.2.0. Tested with an URDF I generated myself and one from the omni.isaac.motion_generation/motion_policy_configs/ path.
