Hello Forum,
on this table in design guide. it says “No mixing for configuration”
But on reference design, it use diffrent UPHY
Do I found something wrong? or Dev kit is is just dev kit?
Also I wonder diffrence between UPHY CLK and PEX CLK, I can’t find description about it.
Thank you,
Regard Bongjin,
Sorry that I don’t understand your quesiton… Your picture does not use mix up UPHY config.
UPHY config means that UPHY could be switched between USB/PCIe and MGBE.
“No mixing for configuration” means you cannot pick UPHY2_lane 4~7 to be MGBE (C0~C3) from config #3 while you also want UPHY0 lane6,7 to be PCIe (from either config#1 or #2 ).
I undestand that comment " No mixing ~"
I wonder, Is which configuration used in evaluation kit?
As i know there is one MGBE, so I guess it must be config #1 , But it use UPHY 4,5,10,11 for M.2 Nvme. Which is not configured in PCI bus on config #1
It is config #1 . You should read the lane number in the left hand side. It is UPHY0, 4,5,6,7.
system
Closed
June 8, 2022, 2:22am
6
