Power cable DP/N 0N08NH that came with the server has 1 6 pin and an 8 pin connector. The M60 card came with a dongle with 2 8 pin connectors. This will leave 2 pins unconnected. Will this cause a problem? My Dell reps have not been helpful. Have not been able to find M60 power wiring specifications.
Hi… You need the part number [490-BCDP] R730 GPU installation kit (this is what I had ordered back when I got a couple of R730 units with M60 GRIDs). Here is a good article showing the connectors and the connection process, which should help: Crashing XenServer 7 with Nvidia M60 (and Dell R730) | Jan Hendriks Blog The big end goes into the GRID, the other two need to be adapted to go to the aux power supply feeds. This is shown nicely in the above-mentioned article.
