we are trying to use GRID M60 cards as vGPUs in our virtual VMware environment (ESXi-6.0.0).
Our Windows machines using the vGPU’s are working fine so far.
We are also using openSUSE Leap42.1 and Suse Linux Enterprise VMs (64-bit) with vGPU’s.
Using NVIDIA-Linux-x86-64-367.64-grid drivers leads to a black screen with a non blinking cursor in the left top of the screen.
The GRID Licensing service is running and connected succesfull to the licensing server.
Xorg doesn’t seem to throw errors while GDM does.
/var/log/gdm/:0-greeter.log:
libGL error: No matching fbConfigs or visuals found
libGL error: failed to load driver: swrast
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 154 (GLX)
Minor opcode of failed request: 3 (X_GLXCreateContext)
Value in failed request: 0x0
Serial number of failed request: 31
Current serial number in output stream: 34
gnome-session-check-accelerated: Helper exited with code 256
Serial number of failed request: 20
Current serial number in output stream: 23
** (process:26085): WARNING **: software acceleration check failed: Child process exited with code 1
Xorg is using the card and does load the Nvidia driver.
gdm_log_error.txt (1.09 KB)
pci_device_nvidia.txt (123 Bytes)
nvidia-bug-report.log.gz (176 KB)
xorg_config.txt (1.56 KB)
xorg_log.txt (12.2 KB)
