I recently returned to Linux for production, too tired of windows.
I run one for my workstation with a K6000 only and the other with a M6000 + 1080Ti on a centOS7.7 with a KMOD isntalled driver 430.50.
the one with the M6000 + 1080Ti doesn’t keep my screen resolution for the Z31 HP after reboot.
I run a HP Z840 and have a HP Z31 on each ws, the one with the K and the one with the M. I use those Quadro to drive the 10bit monitors for color purposes in my CG and Comp workflow.
I checked the xorg.conf:
nvidia-settings: X configuration file generated by nvidia-settings
nvidia-settings: version 430.50
Section “ServerLayout”
Identifier “Layout0”
Screen 0 “Screen0” 0 0
InputDevice “Keyboard0” “CoreKeyboard”
InputDevice “Mouse0” “CorePointer”
Option “Xinerama” “0”
EndSection
Section “Files”
EndSection
Section “InputDevice”
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/input/mice"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section “Monitor”
# HorizSync source: edid, VertRefresh source: edid
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Ancor Communications Inc ASUS PB278"
HorizSync 24.0 - 99.0
VertRefresh 24.0 - 76.0
Option "DPMS"
EndSection
Section “Device”
Identifier “Device0”
Driver “nvidia”
VendorName “NVIDIA Corporation”
BoardName “Quadro M6000”
BusID “PCI:6:0:0”
EndSection
Section “Screen”
Removed Option “metamodes” “DP-2: +0+720, DP-6: 4096x2160 +2560+0”
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "DFP-3"
Option "metamodes" "DP-2: nvidia-auto-select +0+0, DP-6: 4096x2160 +2560+0"
Option "SLI" "Off"
Option "MultiGPU" "Off"
Option "BaseMosaic" "off"
SubSection "Display"
Depth 24
EndSubSection
EndSection
Obviously, the nvidia-auto-select is one guys I change back to 4096x2560 but never stays.
The 1080Ti is not really present as its own 1080Ti code.
The lsci output gives me those 2 addresses:
06:00.0 VGA compatible controller: NVIDIA Corporation GM200GL [Quadro M6000] (rev a1)
84:00.0 VGA compatible controller: NVIDIA Corporation GP102 [GeForce GTX 1080 Ti] (rev a1)
Is there a way to have those 2 babes cohabiting and being fully registered by my system as well as having my resolution being stored and used at reboot ?
Thank you in advance,
Tanguy
