while working with the Xavier NX MMC SOM on our custom board I recognized that the mac adress is set randomly.
Following error shows up on bootup:
eqos 2490000.ether_qos (unnamed net_device) (uninitialized): ether-mac read from DT failed -99
It looks like the SOM can not read its own eeprom, when trying to read i2c on address 0x50 I only get timeouts:
sudo i2cdump -y 0 0x50
No size specified (using byte-data access)
0 1 2 3 4 5 6 7 8 9 a b c d e f 0123456789abcdef
00: ^C[ 1185.882925] tegra-i2c 3160000.i2c: pio timed out addr: 0x50 tlen:28 rlen:4
[ 1185.883198] tegra-i2c 3160000.i2c: --- register dump for debugging ----
[ 1185.883339] tegra-i2c 3160000.i2c: I2C_CNFG - 0x22c00
[ 1185.883530] tegra-i2c 3160000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 1185.883674] tegra-i2c 3160000.i2c: I2C_FIFO_CONTROL - 0x0
[ 1185.883786] tegra-i2c 3160000.i2c: I2C_FIFO_STATUS - 0x800080
[ 1185.883911] tegra-i2c 3160000.i2c: I2C_MST_FIFO_CONTROL - 0x70000
[ 1185.884095] tegra-i2c 3160000.i2c: I2C_MST_FIFO_STATUS - 0x7c0000
[ 1185.884230] tegra-i2c 3160000.i2c: I2C_MST_PACKET_TRANSFER_CNT - 0x0
[ 1185.884365] tegra-i2c 3160000.i2c: I2C_INT_MASK - 0x7d
[ 1185.884469] tegra-i2c 3160000.i2c: I2C_INT_STATUS - 0x2
[ 1185.884585] tegra-i2c 3160000.i2c: i2c transfer timed out addr: 0x50
I have not changed pinmux or dtb in regards to 3160000. Any idea how to get the correct mac address?
Thank you
