I want to control the leds as I want using the p9813 led driver and I am using Jetson Nano. There is a ready-made code that I found on github. I try this but I get module error. I’ve looked through machine modules from Pypi and I’m still getting the same error even though I’ve installed a few of them. Which machine module do I need to install?
#set the second LED to green
chain[1] = (0, 255, 0)
#rite data to all LEDs
chain.write()
#make all LEDs red
chain.fill((255,0,0))
chain.write()
#turn off all LEDs
chain.reset()
I have micropython-p9813 (1.0.0), machine (0.0.1) and Python-Machine (1.0.2) but I get an error while installing machine-py. I got this error in other places as well, but I could not solve it. I am using pip3.
Command “python setup.py egg_info” failed with error code 1 in /tmp/pip-build-f1m5t3ju/matplotlib/
Or is there any other way i can control the led driver with jetson nano?
I looked at the link you sent, but although I did it step by step, I couldn’t quite understand it. sample scripts do not work because it is a module used in rasberry pi. I guess I need to examine the complete library API part?
Additionally, do you have a solution for the machine module?
I have examined this link in detail, but unfortunately I could not do exactly what I wanted to do. This defines the pins using gpio in the link you posted. But I also use the p9813 library. Here I need to import machine
and some functions in this library are used. So actually I still haven’t been able to do exactly what I wanted to do.
As I mentioned, I also specified the modules I loaded in the source attachment. Is there anything else I should do?
