macOS Something happened, please contact support or try restarting the application and installer
Just like the title.
I found the same error in the old post , but no solution found .
thanks .
I found the following error messages in the $HOME/.nvwb/logs/workbench.log
{"level":"info","time":"2025-02-24T11:32:04+08:00","message":"starting host introspection"}
{"level":"error","error":"exit status 1","command":"podman --version","stderr":"path \"/Users/luosen/.config\" exists and it is not owned by the current user\n","stdout":"","time":"2025-02-24T11:32:04+08:00","message":"error when calling bash command"}
{"level":"error","error":"failed to load host state: Failed to check podman state: error when calling bash command: path \"/Users/luosen/.config\" exists and it is not owned by the current user\n: exit status 1","time":"2025-02-24T11:32:04+08:00","message":"an error occurred while checking server info. try again"}
