I’m having a lot of trouble getting a repo I downloaded to install. I’m using Cuda 11.8, and have tried using different versions of cuda hoping this would fix the error, but I haven’t had any luck. Here’s the portion of the Makefile which is giving me trouble:
####### Sub-libraries
cuclean: compiler_cu_clean
mocclean: compiler_moc_header_clean compiler_moc_objc_header_clean compiler_moc_source_clean
mocables: compiler_moc_header_make_all compiler_moc_objc_header_make_all compiler_moc_source_make_all
check: first
benchmark: first
compiler_cu_make_all: gradients.o padding.o conversions.o blocks.o hog.o descriptor.o svm.o timer.o detections.o nms.o
compiler_cu_clean:
-$(DEL_FILE) gradients.o padding.o conversions.o blocks.o hog.o descriptor.o svm.o timer.o detections.o nms.o
gradients.o: gradients.cu
nvcc -arch=sm_52 -Xcompiler -fPIC -Xcompiler -pipe $(DEFINES) $(INCPATH) -D__cplusplus=201402L -D__GNUC__=9 -D__GNUC_MINOR__=4 -D__GNUC_PATCHLEVEL__=0 -c -o gradients.o gradients.cu
padding.o: padding.cu
nvcc -arch=sm_52 -Xcompiler -fPIC -Xcompiler -pipe $(DEFINES) $(INCPATH) -D__cplusplus=201402L -D__GNUC__=9 -D__GNUC_MINOR__=4 -D__GNUC_PATCHLEVEL__=0 -c -o padding.o padding.cu
conversions.o: conversions.cu
nvcc -arch=sm_52 -Xcompiler -fPIC -Xcompiler -pipe $(DEFINES) $(INCPATH) -D__cplusplus=201402L -D__GNUC__=9 -D__GNUC_MINOR__=4 -D__GNUC_PATCHLEVEL__=0 -c -o conversions.o conversions.cu
blocks.o: blocks.cu
nvcc -arch=sm_52 -Xcompiler -fPIC -Xcompiler -pipe $(DEFINES) $(INCPATH) -D__cplusplus=201402L -D__GNUC__=9 -D__GNUC_MINOR__=4 -D__GNUC_PATCHLEVEL__=0 -c -o blocks.o blocks.cu
hog.o: hog.cu
nvcc -arch=sm_52 -Xcompiler -fPIC -Xcompiler -pipe $(DEFINES) $(INCPATH) -D__cplusplus=201402L -D__GNUC__=9 -D__GNUC_MINOR__=4 -D__GNUC_PATCHLEVEL__=0 -c -o hog.o hog.cu
descriptor.o: descriptor.cu
nvcc -arch=sm_52 -Xcompiler -fPIC -Xcompiler -pipe $(DEFINES) $(INCPATH) -D__cplusplus=201402L -D__GNUC__=9 -D__GNUC_MINOR__=4 -D__GNUC_PATCHLEVEL__=0 -c -o descriptor.o descriptor.cu
svm.o: svm.cu
nvcc -arch=sm_52 -Xcompiler -fPIC -Xcompiler -pipe $(DEFINES) $(INCPATH) -D__cplusplus=201402L -D__GNUC__=9 -D__GNUC_MINOR__=4 -D__GNUC_PATCHLEVEL__=0 -c -o svm.o svm.cu
timer.o: timer.cu
nvcc -arch=sm_52 -Xcompiler -fPIC -Xcompiler -pipe $(DEFINES) $(INCPATH) -D__cplusplus=201402L -D__GNUC__=9 -D__GNUC_MINOR__=4 -D__GNUC_PATCHLEVEL__=0 -c -o timer.o timer.cu
detections.o: detections.cu
nvcc -arch=sm_52 -Xcompiler -fPIC -Xcompiler -pipe $(DEFINES) $(INCPATH) -D__cplusplus=201402L -D__GNUC__=9 -D__GNUC_MINOR__=4 -D__GNUC_PATCHLEVEL__=0 -c -o detections.o detections.cu
nms.o: nms.cu
nvcc -arch=sm_52 -Xcompiler -fPIC -Xcompiler -pipe $(DEFINES) $(INCPATH) -D__cplusplus=201402L -D__GNUC__=9 -D__GNUC_MINOR__=4 -D__GNUC_PATCHLEVEL__=0 -c -o nms.o nms.cu
compiler_rcc_make_all:
compiler_rcc_clean:
compiler_moc_predefs_make_all: moc_predefs.h
compiler_moc_predefs_clean:
-$(DEL_FILE) moc_predefs.h
moc_predefs.h: /usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/data/dummy.cpp
g++ -pipe -g -Wall -W -dM -E -o moc_predefs.h /usr/lib/x86_64-linux-gnu/qt5/mkspecs/features/data/dummy.cpp
compiler_moc_header_make_all:
compiler_moc_header_clean:
compiler_moc_objc_header_make_all:
compiler_moc_objc_header_clean:
compiler_moc_source_make_all:
compiler_moc_source_clean:
compiler_yacc_decl_make_all:
compiler_yacc_decl_clean:
compiler_yacc_impl_make_all:
compiler_yacc_impl_clean:
compiler_lex_make_all:
compiler_lex_clean:
compiler_clean: compiler_cu_clean compiler_moc_predefs_clean
####### Compile
cudaHOG.o: cudaHOG.cpp cudaHOG.h \
roi.h \
hog.h \
detections.h \
svm.h \
global.h \
parameters.h \
ext/Vector.h \
ext/Matrix.h
$(CXX) -c $(CXXFLAGS) $(INCPATH) -o cudaHOG.o cudaHOG.cpp
parameters.o: parameters.cpp global.h \
parameters.h
$(CXX) -c $(CXXFLAGS) $(INCPATH) -o parameters.o parameters.cpp
####### Install
install: FORCE
uninstall: FORCE
FORCE:
I’ve seen a lot of stuff on other posts about making sure the arguments for lines like this are separated properly, which might be what is causing the error
But I’m not sure what the proper syntax should look like.
Thanks! Any help is greatly appreciated
