Can someone help me, which part that i should change in this source to perform fcm
because basic kmeans is random choosing the center cluster and use euclidean distance, while fcm using memberships value to choosing the centroid ?
kmeans make value of boolean 1 or 0
fcm make fuzzy value between 1 and 0
// Copyright (c) 2005 Wei-keng Liao
// Copyright (c) 2011 Serban Giuroiu
#include <stdio.h>
#include <stdlib.h>
#include "kmeans.h"
static inline int nextPowerOfTwo(int n) {
n--;
n = n >> 1 | n;
n = n >> 2 | n;
n = n >> 4 | n;
n = n >> 8 | n;
n = n >> 16 | n;
// n = n >> 32 | n; // For 64-bit ints
return ++n;
/*----< euclid_dist_2() >----------------------------------------------------*/
/* square of Euclid distance between two multi-dimensional points */
__host__ __device__ inline static
float euclid_dist_2(int numCoords,
int numObjs,
int numClusters,
float *objects, // [numCoords][numObjs]
float *clusters, // [numCoords][numClusters]
int objectId,
int clusterId)
int i;
float ans=0.0;
for (i = 0; i < numCoords; i++) {
ans += (objects[numObjs * i + objectId] - clusters[numClusters * i + clusterId]) *
(objects[numObjs * i + objectId] - clusters[numClusters * i + clusterId]);
return(ans);
/*----< find_nearest_cluster() >---------------------------------------------*/
__global__ static
void find_nearest_cluster(int numCoords,
int numObjs,
int numClusters,
float *deviceClusters, // [numCoords][numClusters]
int *membership, // [numObjs]
int *intermediates)
extern __shared__ char sharedMemory[];
// The type chosen for membershipChanged must be large enough to support
// reductions! There are blockDim.x elements, one for each thread in the
// block. See numThreadsPerClusterBlock in cuda_kmeans().
unsigned char *membershipChanged = (unsigned char *)sharedMemory;
#if BLOCK_SHARED_MEM_OPTIMIZATION
float *clusters = (float *)(sharedMemory + blockDim.x);
#else
float *clusters = deviceClusters;
#endif
membershipChanged[threadIdx.x] = 0;
// BEWARE: We can overrun our shared memory here if there are too many
// clusters or too many coordinates! For reference, a Tesla C1060 has 16
// KiB of shared memory per block, and a GeForce GTX 480 has 48 KiB of
// shared memory per block.
for (int i = threadIdx.x; i < numClusters; i += blockDim.x) {
for (int j = 0; j < numCoords; j++) {
clusters[numClusters * j + i] = deviceClusters[numClusters * j + i];
__syncthreads();
#endif
int objectId = blockDim.x * blockIdx.x + threadIdx.x;
if (objectId < numObjs) {
int index, i;
float dist, min_dist;
/* find the cluster id that has min distance to object */
index = 0;
min_dist = euclid_dist_2(numCoords, numObjs, numClusters,
objects, clusters, objectId, 0);
for (i=1; i<numClusters; i++) {
objects, clusters, objectId, i);
/* no need square root */
if (dist < min_dist) { /* find the min and its array index */
min_dist = dist;
index = i;
if (membership[objectId] != index) {
membershipChanged[threadIdx.x] = 1;
/* assign the membership to object objectId */
membership[objectId] = index;
__syncthreads(); // For membershipChanged[]
// blockDim.x *must* be a power of two!
for (unsigned int s = blockDim.x / 2; s > 0; s >>= 1) {
if (threadIdx.x < s) {
membershipChanged[threadIdx.x] +=
membershipChanged[threadIdx.x + s];
__syncthreads();
if (threadIdx.x == 0) {
intermediates[blockIdx.x] = membershipChanged[0];
__global__ static
void compute_delta(int *deviceIntermediates,
int numIntermediates, // The actual number of intermediates
int numIntermediates2) // The next power of two
// The number of elements in this array should be equal to
// numIntermediates2, the number of threads launched. It *must* be a power
// of two!
extern __shared__ unsigned int intermediates[];
// Copy global intermediate values into shared memory.
intermediates[threadIdx.x] =
(threadIdx.x < numIntermediates) ? deviceIntermediates[threadIdx.x] : 0;
__syncthreads();
// numIntermediates2 *must* be a power of two!
for (unsigned int s = numIntermediates2 / 2; s > 0; s >>= 1) {
intermediates[threadIdx.x] += intermediates[threadIdx.x + s];
__syncthreads();
deviceIntermediates[0] = intermediates[0];
/*----< cuda_kmeans() >-------------------------------------------------------*/
// DATA LAYOUT
// objects [numObjs][numCoords]
// clusters [numClusters][numCoords]
// dimObjects [numCoords][numObjs]
// dimClusters [numCoords][numClusters]
// newClusters [numCoords][numClusters]
// deviceObjects [numCoords][numObjs]
// deviceClusters [numCoords][numClusters]
/* return an array of cluster centers of size [numClusters][numCoords] */
float** cuda_kmeans(float **objects, /* in: [numObjs][numCoords] */
int numCoords, /* no. features */
int numObjs, /* no. objects */
int numClusters, /* no. clusters */
float threshold, /* % objects change membership */
int *membership, /* out: [numObjs] */
int *loop_iterations)
int i, j, index, loop=0;
int *newClusterSize; /* [numClusters]: no. objects assigned in each
new cluster */
float delta; /* % of objects change their clusters */
float **dimObjects;
float **clusters; /* out: [numClusters][numCoords] */
float **dimClusters;
float **newClusters; /* [numCoords][numClusters] */
float *deviceObjects;
float *deviceClusters;
int *deviceMembership;
int *deviceIntermediates;
// Copy objects given in [numObjs][numCoords] layout to new
// [numCoords][numObjs] layout
malloc2D(dimObjects, numCoords, numObjs, float);
for (j = 0; j < numObjs; j++) {
dimObjects[i][j] = objects[j][i];
/* pick first numClusters elements of objects[] as initial cluster centers*/
malloc2D(dimClusters, numCoords, numClusters, float);
for (j = 0; j < numClusters; j++) {
dimClusters[i][j] = dimObjects[i][j];
/* initialize membership[] */
for (i=0; i<numObjs; i++) membership[i] = -1;
/* need to initialize newClusterSize and newClusters[0] to all 0 */
newClusterSize = (int*) calloc(numClusters, sizeof(int));
assert(newClusterSize != NULL);
malloc2D(newClusters, numCoords, numClusters, float);
memset(newClusters[0], 0, numCoords * numClusters * sizeof(float));
// To support reduction, numThreadsPerClusterBlock *must* be a power of
// two, and it *must* be no larger than the number of bits that will
// fit into an unsigned char, the type used to keep track of membership
// changes in the kernel.
const unsigned int numThreadsPerClusterBlock = 128;
const unsigned int numClusterBlocks =
(numObjs + numThreadsPerClusterBlock - 1) / numThreadsPerClusterBlock;
const unsigned int clusterBlockSharedDataSize =
numThreadsPerClusterBlock * sizeof(unsigned char) +
numClusters * numCoords * sizeof(float);
cudaDeviceProp deviceProp;
int deviceNum;
cudaGetDevice(&deviceNum);
cudaGetDeviceProperties(&deviceProp, deviceNum);
if (clusterBlockSharedDataSize > deviceProp.sharedMemPerBlock) {
err("WARNING: Your CUDA hardware has insufficient block shared memory. "
"You need to recompile with BLOCK_SHARED_MEM_OPTIMIZATION=0. "
"See the README for details.\n");
#else
numThreadsPerClusterBlock * sizeof(unsigned char);
#endif
const unsigned int numReductionThreads =
nextPowerOfTwo(numClusterBlocks);
const unsigned int reductionBlockSharedDataSize =
numReductionThreads * sizeof(unsigned int);
checkCuda(cudaMalloc(&deviceObjects, numObjs*numCoords*sizeof(float)));
checkCuda(cudaMalloc(&deviceClusters, numClusters*numCoords*sizeof(float)));
checkCuda(cudaMalloc(&deviceMembership, numObjs*sizeof(int)));
checkCuda(cudaMalloc(&deviceIntermediates, numReductionThreads*sizeof(unsigned int)));
checkCuda(cudaMemcpy(deviceObjects, dimObjects[0],
numObjs*numCoords*sizeof(float), cudaMemcpyHostToDevice));
checkCuda(cudaMemcpy(deviceMembership, membership,
numObjs*sizeof(int), cudaMemcpyHostToDevice));
do {
checkCuda(cudaMemcpy(deviceClusters, dimClusters[0],
numClusters*numCoords*sizeof(float), cudaMemcpyHostToDevice));
<<< numClusterBlocks, numThreadsPerClusterBlock, clusterBlockSharedDataSize >>>
deviceObjects, deviceClusters, deviceMembership, deviceIntermediates);
cudaDeviceSynchronize(); checkLastCudaError();
compute_delta <<< 1, numReductionThreads, reductionBlockSharedDataSize >>>
(deviceIntermediates, numClusterBlocks, numReductionThreads);
int d;
checkCuda(cudaMemcpy(&d, deviceIntermediates,
sizeof(int), cudaMemcpyDeviceToHost));
delta = (float)d;
checkCuda(cudaMemcpy(membership, deviceMembership,
numObjs*sizeof(int), cudaMemcpyDeviceToHost));
for (i=0; i<numObjs; i++) {
/* find the array index of nestest cluster center */
index = membership[i];
/* update new cluster centers : sum of objects located within */
newClusterSize[index]++;
for (j=0; j<numCoords; j++)
newClusters[j][index] += objects[i][j];
// TODO: Flip the nesting order
// TODO: Change layout of newClusters to [numClusters][numCoords]
/* average the sum and replace old cluster centers with newClusters */
for (i=0; i<numClusters; i++) {
for (j=0; j<numCoords; j++) {
if (newClusterSize[i] > 0)
dimClusters[j][i] = newClusters[j][i] / newClusterSize[i];
newClusters[j][i] = 0.0; /* set back to 0 */
newClusterSize[i] = 0; /* set back to 0 */
delta /= numObjs;
} while (delta > threshold && loop++ < 500);
*loop_iterations = loop + 1;
/* allocate a 2D space for returning variable clusters[] (coordinates
of cluster centers) */
malloc2D(clusters, numClusters, numCoords, float);
for (i = 0; i < numClusters; i++) {
for (j = 0; j < numCoords; j++) {
clusters[i][j] = dimClusters[j][i];
checkCuda(cudaFree(deviceObjects));
checkCuda(cudaFree(deviceClusters));
checkCuda(cudaFree(deviceMembership));
checkCuda(cudaFree(deviceIntermediates));
free(dimObjects[0]);
free(dimObjects);
free(dimClusters[0]);
free(dimClusters);
free(newClusters[0]);
free(newClusters);
free(newClusterSize);
return clusters;
