I am taking the following course: " Deployment for Intelligent Video Analytics using DeepStream" from Nvidia DLI.
on Step 6 in the course “6. Custom Parsers and Networks” you need to edit the printf statement then buld the library, but it seems there is a problem with the build:
First the command is referring to file which does not exists: nvdsparsebbox2 there is only nvdsparsebbox. If I edited that command to nvdsparsebbox I am receiving the following error message:
The issue is still present even after doing these steps. sudo apt-get update
output
Get:1 file:/var/cuda-repo-10-0-local-10.0.326 InRelease
Ign:1 file:/var/cuda-repo-10-0-local-10.0.326 InRelease
Get:2 file:/var/visionworks-repo InRelease
Ign:2 file:/var/visionworks-repo InRelease
Get:3 file:/var/visionworks-sfm-repo InRelease
Ign:3 file:/var/visionworks-sfm-repo InRelease
Get:4 file:/var/visionworks-tracking-repo InRelease
Ign:4 file:/var/visionworks-tracking-repo InRelease
Get:5 file:/var/cuda-repo-10-0-local-10.0.326 Release [574 B]
Get:6 file:/var/visionworks-repo Release [1,999 B]
Get:7 file:/var/visionworks-sfm-repo Release [2,003 B]
Get:8 file:/var/visionworks-tracking-repo Release [2,008 B]
Hit:10 https://nvidia.github.io/libnvidia-container/stable/ubuntu18.04/arm64 InRelease
Hit:11 https://repo.download.nvidia.com/jetson/common r32.4 InRelease
Hit:12 Index of /ubuntu-ports bionic InRelease
Hit:13 https://nvidia.github.io/nvidia-container-runtime/stable/ubuntu18.04/arm64 InRelease
Hit:15 https://nvidia.github.io/nvidia-docker/ubuntu18.04/arm64 InRelease
Get:16 Index of /ubuntu-ports bionic-updates InRelease [88.7 kB]
Hit:18 https://repo.download.nvidia.com/jetson/t210 r32.4 InRelease
Hit:20 Index of /ubuntu-ports bionic-backports InRelease
Get:21 Index of /ubuntu-ports bionic-security InRelease [88.7 kB]
Fetched 177 kB in 3s (60.7 kB/s)
Reading package lists… Done
sudo apt-get install build-essential -y
output
Building dependency tree
Reading state information… Done
build-essential is already the newest version (12.4ubuntu1).
0 upgraded, 0 newly installed, 0 to remove and 337 not upgraded.
oot@f12f426e4f07:/opt/nvidia/deepstream/deepstream-5.0/sources/libs/nvdsinfer_cust
omparser# make all
g++ -o libnvds_infercustomparser.so nvdsinfer_custombboxparser.cpp nvdsinfer_customclassifierparser.cpp -Wall -std=c++11 -shared -fPIC -I…/…/includes -Wl,–start-group -lnvinfer -lnvparsers -Wl,–end-group
make: g++: Command not found
Makefile:40: recipe for target ‘libnvds_infercustomparser.so’ failed
make: *** [libnvds_infercustomparser.so] Error 127
