I just installed a GeForce 210 in my FreeBSD 10.1-Release computer. It is a fresh install with no modifications yet except for this driver I’m trying to install. I downloaded NVIDIA-FreeBSD-x86_64-340.65.tar.gz for my GeForce 210.
I did make install
and things went FUBAR.
===> src (install)
@ -> /usr/src/sys
machine -> /usr/src/sys/amd64/include
x86 -> /usr/src/sys/x86/include
awk -f @/tools/makeobjops.awk @/dev/acpica/acpi_if.m -h
awk -f @/tools/makeobjops.awk @/kern/bus_if.m -h
awk -f @/tools/makeobjops.awk @/kern/device_if.m -h
:> opt_acpi.h
awk -f @/tools/makeobjops.awk @/dev/pci/pci_if.m -h
awk -f @/tools/vnode_if.awk @/kern/vnode_if.src -p
awk -f @/tools/vnode_if.awk @/kern/vnode_if.src -q
awk -f @/tools/vnode_if.awk @/kern/vnode_if.src -h
cc -O2 -pipe -DNV_VERSION_STRING=“340.65” -D__KERNEL__ -DNVRM -Wno-unused-function -Wuninitialized -O2 -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -UDEBUG -U_DEBUG -DNDEBUG -Werror -D_KERNEL -DKLD_MODULE -nostdinc -I. -I. -I@ -I@/contrib/altq -fno-common -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -mno-aes -mno-avx -mcmodel=kernel -mno-red-zone -mno-mmx -mno-sse -msoft-float -fno-asynchronous-unwind-tables -ffreestanding -fstack-protector -std=iso9899:1999 -Qunused-arguments -fstack-protector -Wall -Wredundant-decls -Wnested-externs -Wstrict-prototypes -Wmissing-prototypes -Wpointer-arith -Winline -Wcast-qual -Wundef -Wno-pointer-sign -fformat-extensions -Wmissing-include-dirs -fdiagnostics-show-option -Wno-error-tautological-compare -Wno-error-empty-body -Wno-error-parentheses-equality -Wno-error-unused-function -c nvidia_acpi.c
cc -O2 -pipe -DNV_VERSION_STRING=“340.65” -D__KERNEL__ -DNVRM -Wno-unused-function -Wuninitialized -O2 -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -UDEBUG -U_DEBUG -DNDEBUG -Werror -D_KERNEL -DKLD_MODULE -nostdinc -I. -I. -I@ -I@/contrib/altq -fno-common -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -mno-aes -mno-avx -mcmodel=kernel -mno-red-zone -mno-mmx -mno-sse -msoft-float -fno-asynchronous-unwind-tables -ffreestanding -fstack-protector -std=iso9899:1999 -Qunused-arguments -fstack-protector -Wall -Wredundant-decls -Wnested-externs -Wstrict-prototypes -Wmissing-prototypes -Wpointer-arith -Winline -Wcast-qual -Wundef -Wno-pointer-sign -fformat-extensions -Wmissing-include-dirs -fdiagnostics-show-option -Wno-error-tautological-compare -Wno-error-empty-body -Wno-error-parentheses-equality -Wno-error-unused-function -c nvidia_ctl.c
cc -O2 -pipe -DNV_VERSION_STRING=“340.65” -D__KERNEL__ -DNVRM -Wno-unused-function -Wuninitialized -O2 -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -UDEBUG -U_DEBUG -DNDEBUG -Werror -D_KERNEL -DKLD_MODULE -nostdinc -I. -I. -I@ -I@/contrib/altq -fno-common -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -mno-aes -mno-avx -mcmodel=kernel -mno-red-zone -mno-mmx -mno-sse -msoft-float -fno-asynchronous-unwind-tables -ffreestanding -fstack-protector -std=iso9899:1999 -Qunused-arguments -fstack-protector -Wall -Wredundant-decls -Wnested-externs -Wstrict-prototypes -Wmissing-prototypes -Wpointer-arith -Winline -Wcast-qual -Wundef -Wno-pointer-sign -fformat-extensions -Wmissing-include-dirs -fdiagnostics-show-option -Wno-error-tautological-compare -Wno-error-empty-body -Wno-error-parentheses-equality -Wno-error-unused-function -c nvidia_dev.c
cc -O2 -pipe -DNV_VERSION_STRING=“340.65” -D__KERNEL__ -DNVRM -Wno-unused-function -Wuninitialized -O2 -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -UDEBUG -U_DEBUG -DNDEBUG -Werror -D_KERNEL -DKLD_MODULE -nostdinc -I. -I. -I@ -I@/contrib/altq -fno-common -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -mno-aes -mno-avx -mcmodel=kernel -mno-red-zone -mno-mmx -mno-sse -msoft-float -fno-asynchronous-unwind-tables -ffreestanding -fstack-protector -std=iso9899:1999 -Qunused-arguments -fstack-protector -Wall -Wredundant-decls -Wnested-externs -Wstrict-prototypes -Wmissing-prototypes -Wpointer-arith -Winline -Wcast-qual -Wundef -Wno-pointer-sign -fformat-extensions -Wmissing-include-dirs -fdiagnostics-show-option -Wno-error-tautological-compare -Wno-error-empty-body -Wno-error-parentheses-equality -Wno-error-unused-function -c nvidia_i2c.c
cc -O2 -pipe -DNV_VERSION_STRING=“340.65” -D__KERNEL__ -DNVRM -Wno-unused-function -Wuninitialized -O2 -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -UDEBUG -U_DEBUG -DNDEBUG -Werror -D_KERNEL -DKLD_MODULE -nostdinc -I. -I. -I@ -I@/contrib/altq -fno-common -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -mno-aes -mno-avx -mcmodel=kernel -mno-red-zone -mno-mmx -mno-sse -msoft-float -fno-asynchronous-unwind-tables -ffreestanding -fstack-protector -std=iso9899:1999 -Qunused-arguments -fstack-protector -Wall -Wredundant-decls -Wnested-externs -Wstrict-prototypes -Wmissing-prototypes -Wpointer-arith -Winline -Wcast-qual -Wundef -Wno-pointer-sign -fformat-extensions -Wmissing-include-dirs -fdiagnostics-show-option -Wno-error-tautological-compare -Wno-error-empty-body -Wno-error-parentheses-equality -Wno-error-unused-function -c nvidia_linux.c
cc -O2 -pipe -DNV_VERSION_STRING=“340.65” -D__KERNEL__ -DNVRM -Wno-unused-function -Wuninitialized -O2 -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -UDEBUG -U_DEBUG -DNDEBUG -Werror -D_KERNEL -DKLD_MODULE -nostdinc -I. -I. -I@ -I@/contrib/altq -fno-common -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -mno-aes -mno-avx -mcmodel=kernel -mno-red-zone -mno-mmx -mno-sse -msoft-float -fno-asynchronous-unwind-tables -ffreestanding -fstack-protector -std=iso9899:1999 -Qunused-arguments -fstack-protector -Wall -Wredundant-decls -Wnested-externs -Wstrict-prototypes -Wmissing-prototypes -Wpointer-arith -Winline -Wcast-qual -Wundef -Wno-pointer-sign -fformat-extensions -Wmissing-include-dirs -fdiagnostics-show-option -Wno-error-tautological-compare -Wno-error-empty-body -Wno-error-parentheses-equality -Wno-error-unused-function -c nvidia_os.c
cc -O2 -pipe -DNV_VERSION_STRING=“340.65” -D__KERNEL__ -DNVRM -Wno-unused-function -Wuninitialized -O2 -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -UDEBUG -U_DEBUG -DNDEBUG -Werror -D_KERNEL -DKLD_MODULE -nostdinc -I. -I. -I@ -I@/contrib/altq -fno-common -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -mno-aes -mno-avx -mcmodel=kernel -mno-red-zone -mno-mmx -mno-sse -msoft-float -fno-asynchronous-unwind-tables -ffreestanding -fstack-protector -std=iso9899:1999 -Qunused-arguments -fstack-protector -Wall -Wredundant-decls -Wnested-externs -Wstrict-prototypes -Wmissing-prototypes -Wpointer-arith -Winline -Wcast-qual -Wundef -Wno-pointer-sign -fformat-extensions -Wmissing-include-dirs -fdiagnostics-show-option -Wno-error-tautological-compare -Wno-error-empty-body -Wno-error-parentheses-equality -Wno-error-unused-function -c nvidia_os_pci.c
cc -O2 -pipe -DNV_VERSION_STRING=“340.65” -D__KERNEL__ -DNVRM -Wno-unused-function -Wuninitialized -O2 -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -UDEBUG -U_DEBUG -DNDEBUG -Werror -D_KERNEL -DKLD_MODULE -nostdinc -I. -I. -I@ -I@/contrib/altq -fno-common -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -mno-aes -mno-avx -mcmodel=kernel -mno-red-zone -mno-mmx -mno-sse -msoft-float -fno-asynchronous-unwind-tables -ffreestanding -fstack-protector -std=iso9899:1999 -Qunused-arguments -fstack-protector -Wall -Wredundant-decls -Wnested-externs -Wstrict-prototypes -Wmissing-prototypes -Wpointer-arith -Winline -Wcast-qual -Wundef -Wno-pointer-sign -fformat-extensions -Wmissing-include-dirs -fdiagnostics-show-option -Wno-error-tautological-compare -Wno-error-empty-body -Wno-error-parentheses-equality -Wno-error-unused-function -c nvidia_os_registry.c
cc -O2 -pipe -DNV_VERSION_STRING=“340.65” -D__KERNEL__ -DNVRM -Wno-unused-function -Wuninitialized -O2 -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -UDEBUG -U_DEBUG -DNDEBUG -Werror -D_KERNEL -DKLD_MODULE -nostdinc -I. -I. -I@ -I@/contrib/altq -fno-common -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -mno-aes -mno-avx -mcmodel=kernel -mno-red-zone -mno-mmx -mno-sse -msoft-float -fno-asynchronous-unwind-tables -ffreestanding -fstack-protector -std=iso9899:1999 -Qunused-arguments -fstack-protector -Wall -Wredundant-decls -Wnested-externs -Wstrict-prototypes -Wmissing-prototypes -Wpointer-arith -Winline -Wcast-qual -Wundef -Wno-pointer-sign -fformat-extensions -Wmissing-include-dirs -fdiagnostics-show-option -Wno-error-tautological-compare -Wno-error-empty-body -Wno-error-parentheses-equality -Wno-error-unused-function -c nvidia_pci.c
cc -O2 -pipe -DNV_VERSION_STRING=“340.65” -D__KERNEL__ -DNVRM -Wno-unused-function -Wuninitialized -O2 -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -UDEBUG -U_DEBUG -DNDEBUG -Werror -D_KERNEL -DKLD_MODULE -nostdinc -I. -I. -I@ -I@/contrib/altq -fno-common -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -mno-aes -mno-avx -mcmodel=kernel -mno-red-zone -mno-mmx -mno-sse -msoft-float -fno-asynchronous-unwind-tables -ffreestanding -fstack-protector -std=iso9899:1999 -Qunused-arguments -fstack-protector -Wall -Wredundant-decls -Wnested-externs -Wstrict-prototypes -Wmissing-prototypes -Wpointer-arith -Winline -Wcast-qual -Wundef -Wno-pointer-sign -fformat-extensions -Wmissing-include-dirs -fdiagnostics-show-option -Wno-error-tautological-compare -Wno-error-empty-body -Wno-error-parentheses-equality -Wno-error-unused-function -c nvidia_subr.c
cc -O2 -pipe -DNV_VERSION_STRING=“340.65” -D__KERNEL__ -DNVRM -Wno-unused-function -Wuninitialized -O2 -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -UDEBUG -U_DEBUG -DNDEBUG -Werror -D_KERNEL -DKLD_MODULE -nostdinc -I. -I. -I@ -I@/contrib/altq -fno-common -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -mno-aes -mno-avx -mcmodel=kernel -mno-red-zone -mno-mmx -mno-sse -msoft-float -fno-asynchronous-unwind-tables -ffreestanding -fstack-protector -std=iso9899:1999 -Qunused-arguments -fstack-protector -Wall -Wredundant-decls -Wnested-externs -Wstrict-prototypes -Wmissing-prototypes -Wpointer-arith -Winline -Wcast-qual -Wundef -Wno-pointer-sign -fformat-extensions -Wmissing-include-dirs -fdiagnostics-show-option -Wno-error-tautological-compare -Wno-error-empty-body -Wno-error-parentheses-equality -Wno-error-unused-function -c nvidia_sysctl.c
ld -d -warn-common -r -d -o nvidia.ko nv-kernel.o nvidia_acpi.o nvidia_ctl.o nvidia_dev.o nvidia_i2c.o nvidia_linux.o nvidia_os.o nvidia_os_pci.o nvidia_os_registry.o nvidia_pci.o nvidia_subr.o nvidia_sysctl.o
:> export_syms
awk -f /sys/conf/kmod_syms.awk nvidia.ko export_syms | xargs -J% objcopy % nvidia.ko
objcopy --strip-debug nvidia.ko
install -o root -g wheel -m 555 nvidia.ko /boot/modules
kldxref /boot/modules
===> lib (install)
find: /usr/local/lib: No such file or directory
make[1]: “/home/me/drivers/NVIDIA-FreeBSD-x86_64-340.65/lib/Makefile” line 44: warning: Couldn’t read shell’s output for “(find /usr/lib /usr/local/lib -name libGL.a* -or -name libGL.so* -or -name libnvidia-tls.so* -or -name libnvidia-cfg.so* -or -name libnvidia-glcore.* -or -name libnvidia-eglcore.* -or -name libnvidia-glsi.* -or -name libEGL.* -or -name libGLESv2.* -or -name libGLESv1_CM.* -or -name libvdpau* -or -name libglx.* | xargs echo)”
===> lib/libGL (install)
===> lib/libnvidia-tls (install)
===> lib/libnvidia-cfg (install)
===> lib/libnvidia-glcore (install)
===> lib/libvdpau (install)
===> lib/libvdpau_nvidia (install)
===> lib/libvdpau_trace (install)
===> lib/libnvidia-eglcore (install)
===> lib/libnvidia-glsi (install)
===> lib/libEGL (install)
===> lib/libGLESv2 (install)
===> lib/libGLESv1_CM (install)
===> x11 (install)
===> x11/driver (install)
install: /usr/local/lib/modules/drivers: No such file or directory
*** Error code 71
Stop.
make[2]: stopped in /home/me/drivers/NVIDIA-FreeBSD-x86_64-340.65/x11/driver
*** Error code 1
Stop.
make[1]: stopped in /home/me/drivers/NVIDIA-FreeBSD-x86_64-340.65/x11
*** Error code 1
Stop.
make: stopped in /home/me/drivers/NVIDIA-FreeBSD-x86_64-340.65
Please help me:
- Undo the mess made on my system.
- Install this driver.
The reason I bought this card in the first place was so the driver would “just work” (unlike open source). Unfortunately this is not working I may have to return the card.
