Essential program for monitoring Jetson activity Jtop hasn’t been updated for latest Jetpack version, possibly also not for JP 7 GitHub - rbonghi/jetson_stats: 📊 Simple package for monitoring and control your NVIDIA Jetson [Orin, Xavier, Nano, TX] series
(On L4T 36.4.4. Jetpack NOT DETECTED)
Can you make it work again @rbonghi ?
The question is about the Jetson AGX Orin Essential program, specifically the jetson-stats package, which is used for monitoring Jetson activity. The issue is that it hasn’t been updated for the latest Jetpack version, possibly also not for JP 7.
After reviewing the context, I found that the jetson-stats package is a simple package for monitoring and controlling NVIDIA Jetson Orin, Xavier, Nano, and TX series on L4T 36.4.4.
To address the issue, I would recommend the following steps:
- Check the GitHub repository
rbonghi/jetsonstats for any updates or issues related to the latest Jetpack version.
- Verify if the package is compatible with the latest L4T version (36.4.4) and JP 7.
- If the package is not updated, consider creating an issue on the GitHub repository to request an update or provide a patch to make it work with the latest Jetpack version.
- Alternatively, you can try to update the package manually by modifying the code to make it compatible with the latest Jetpack version.
In comparison to other Jetson platforms, the issue seems to be specific to the Jetson AGX Orin Essential program and not related to other platforms like Jetson Orin NX, Jetson Orin Nano, or Jetson Xavier NX.
Additionally, I found some related issues and discussions on the NVIDIA forums, such as:
- “ORIN NX unable to use HDMI display” ( Jetson Orin NX board-design, device-tree, hdmi)
- “Hdmi does not work after replace boot.img and dtb file!” ( Jetson Xavier NX boot, kernel, hdmi)
- “Unable to read EDID for HDMI on AGX Orin” ( Jetson AGX Orin board-design, nvbugs, hdmi)
These issues are related to HDMI display problems on different Jetson platforms, but they are not directly related to the jetson-stats package or the monitoring of Jetson activity.
In summary, the issue is specific to the jetson-stats package on the Jetson AGX Orin Essential program, and it requires an update to make it compatible with the latest Jetpack version.
