Make object file to use in another cpp project I need some guidance please
Hi guys,
I need to use a cuda kernel in my cpp project, but my project already has a Makefile. Since I don’t have much experience in working with Makefiles, I really need your assistance.
So I have my kernel and a kernel caller function (called “gpucaller”), both inside my cuda_kernel.cu file.
#ifndef _CUDA_KERNEL_H_
#define _CUDA_KERNEL_H_
#define MAX_QUBITS 25
#define BLOCKDIM 512
#define MAX_TERMS_PER_BLOCK (2*BLOCKDIM)
// includes
#include <iostream>
using namespace std;
#include <cutil_inline.h>
//#include "operator.h"
#define THREAD_MASK (~0ul << 1)
__constant__ float devOpBit[2][2];
* N - number of terms
* qbCount - the number of gates to apply
* qbStart - index of the first qubit to apply the gates on
__global__ void qcl1(cuFloatComplex *a, int N, int qbCount, int blockGrpSize, int k)
	//int idx = blockIdx.x * BLOCKDIM + threadIdx.x;
	//int tx = threadIdx.x;
	cuFloatComplex t0_0, t0_1, t1_0, t1_1;
	int x0_idx, x1_idx;
	int i, grpSize, b0_idx, b1_idx;
	__shared__ cuFloatComplex aS[MAX_TERMS_PER_BLOCK];
void gpucaller(opBit* op, quState* q) {
	// make an operator copy
    double** myOpBit = op->getDeviceReadyOpBit();
	unsigned int timer = 0;
    cuFloatComplex *a_d;
	long int N = 1 << q.mapbits();
	int size = sizeof(cuFloatComplex) * N;
	// start timer
    cutilCheckError( cutCreateTimer( &timer));
    cutilCheckError( cutStartTimer( timer));
    // allocate device memory
	cudaMalloc((void**)&a_d,size);
    // copy host memory to device
	cudaMemcpy(a_d, q.termsarray, size, cudaMemcpyHostToDevice);
	// copy quantic operator to constant memory
	cutilSafeCall( cudaMemcpyToSymbol(devOpBit, myOpBit, 2*sizeof(float[2]), 0) );
	printf("Cuda errors: %s\n", cudaGetErrorString( cudaGetLastError() ) );
	// setup execution parameters
    dim3 dimBlock(BLOCKDIM, 1, 1);
	int n_blocks = N/MAX_TERMS_PER_BLOCK + (N%MAX_TERMS_PER_BLOCK == 0 ? 0:1);
    dim3 dimGrid(n_blocks, 1, 1);
int blockGrpSize = 1;
    int qbCount = q.mapbits();
    int gates;
    int k=0;
gates = (qbCount > 10) ? 10 : qbCount;
    qbCount -= gates;
	// execute the kernel
	qcl1<<< dimGrid, dimBlock >>>(a_d, N, gates, blockGrpSize, k);
	// check if kernel execution generated and error
	cutilCheckMsg("Kernel execution failed");
	while (qbCount > 0) {
		qbCount--;
		blockGrpSize *= 2;
		k++;
		qcl1<<< dimGrid, dimBlock >>>(a_d, N, 1, blockGrpSize, k);
    // copy result from device to host
	cudaMemcpy(q.termsarray, a_d, size, cudaMemcpyDeviceToHost);
	// stop timer
    cutilCheckError( cutStopTimer( timer));
    printf( "Optimized - GPU Processing time: %f (ms)\n", cutGetTimerValue( timer));
    cutilCheckError( cutDeleteTimer( timer));
    // cleanup memory on device
	cudaFree(a_d);
    cudaThreadExit();
#endif // #ifndef _CUDA_KERNEL_H_
In the project’s source file where I need to call “gpucaller” I’ve declared it like this:
extern "C"
void gpucaller(opBit* op, quState* q);
There is only one call to “gpucaller” within my project’s source file.
So what I think I need is to generate an object file for the .cu file, then link it to the other .o files generated by my project’s Makefile. I hope that I got this right.
For the first task (ie generating the object file for the .cu file), I was thinking that I should use the Makefile from the SDK, but to modify it so as to only produce my object file.
The SDK’s Makefile consists of these 2 files:
# Copyright 1993-2006 NVIDIA Corporation.  All rights reserved.
# NOTICE TO USER:
# This source code is subject to NVIDIA ownership rights under U.S. and
# international Copyright laws.
# NVIDIA MAKES NO REPRESENTATION ABOUT THE SUITABILITY OF THIS SOURCE
# CODE FOR ANY PURPOSE.  IT IS PROVIDED "AS IS" WITHOUT EXPRESS OR
# IMPLIED WARRANTY OF ANY KIND.  NVIDIA DISCLAIMS ALL WARRANTIES WITH
# REGARD TO THIS SOURCE CODE, INCLUDING ALL IMPLIED WARRANTIES OF
# MERCHANTABILITY, NONINFRINGEMENT, AND FITNESS FOR A PARTICULAR PURPOSE.
# IN NO EVENT SHALL NVIDIA BE LIABLE FOR ANY SPECIAL, INDIRECT, INCIDENTAL,
# OR CONSEQUENTIAL DAMAGES, OR ANY DAMAGES WHATSOEVER RESULTING FROM LOSS
# OF USE, DATA OR PROFITS, WHETHER IN AN ACTION OF CONTRACT, NEGLIGENCE
# OR OTHER TORTIOUS ACTION, ARISING OUT OF OR IN CONNECTION WITH THE USE
# OR PERFORMANCE OF THIS SOURCE CODE.
# U.S. Government End Users.  This source code is a "commercial item" as
# that term is defined at 48 C.F.R. 2.101 (OCT 1995), consisting  of
# "commercial computer software" and "commercial computer software
# documentation" as such terms are used in 48 C.F.R. 12.212 (SEPT 1995)
# and is provided to the U.S. Government only as a commercial end item.
# Consistent with 48 C.F.R.12.212 and 48 C.F.R. 227.7202-1 through
# 227.7202-4 (JUNE 1995), all U.S. Government End Users acquire the
# source code with only those rights set forth herein.
# Build script for project
# Add source files here
EXECUTABLE	:= template
# CUDA source files (compiled with cudacc)
CUFILES		:= template.cu
# CUDA dependency files
CU_DEPS		:= \
	template_kernel.cu \
# C/C++ source files (compiled with gcc / c++)
CCFILES		:= \
	template_gold.cpp \
# Rules and targets
include ../../common/common.mk
and common.mk
# Copyright 1993-2010 NVIDIA Corporation.  All rights reserved.
# NVIDIA Corporation and its licensors retain all intellectual property and
# proprietary rights in and to this software and related documentation.
# Any use, reproduction, disclosure, or distribution of this software
# and related documentation without an express license agreement from
# NVIDIA Corporation is strictly prohibited.
# Please refer to the applicable NVIDIA end user license agreement (EULA)
# associated with this source code for terms and conditions that govern
# your use of this NVIDIA software.
# Common build script for CUDA source projects for Linux and Mac platforms
.SUFFIXES : .cu .cu_dbg.o .c_dbg.o .cpp_dbg.o .cu_rel.o .c_rel.o .cpp_rel.o .cubin .ptx
# Add new SM Versions here as devices with new Compute Capability are released
SM_VERSIONS   := 10 11 12 13 20
CUDA_INSTALL_PATH ?= /usr/local/cuda
ifdef cuda-install
	CUDA_INSTALL_PATH := $(cuda-install)
endif
# detect OS
OSUPPER = $(shell uname -s 2>/dev/null | tr [:lower:] [:upper:])
OSLOWER = $(shell uname -s 2>/dev/null | tr [:upper:] [:lower:])
# 'linux' is output for Linux system, 'darwin' for OS X
DARWIN = $(strip $(findstring DARWIN, $(OSUPPER)))
ifneq ($(DARWIN),)
   SNOWLEOPARD = $(strip $(findstring 10.6, $(shell egrep "<string>10\.6" /System/Library/CoreServices/SystemVersion.plist)))
endif
# detect 32-bit or 64-bit platform
HP_64 = $(shell uname -m | grep 64)
OSARCH= $(shell uname -m)
# Basic directory setup for SDK
# (override directories only if they are not already defined)
SRCDIR     ?=
ROOTDIR    ?= ..
ROOTBINDIR ?= $(ROOTDIR)/../bin
BINDIR     ?= $(ROOTBINDIR)/$(OSLOWER)
ROOTOBJDIR ?= obj
LIBDIR     := $(ROOTDIR)/../lib
COMMONDIR  := $(ROOTDIR)/../common
SHAREDDIR  := $(ROOTDIR)/../../shared/
# Compilers
NVCC       := $(CUDA_INSTALL_PATH)/bin/nvcc
CXX        := g++ -fPIC
CC         := gcc -fPIC
LINK       := g++ -fPIC
# Includes
INCLUDES  += -I. -I$(CUDA_INSTALL_PATH)/include -I$(COMMONDIR)/inc -I$(SHAREDDIR)/inc
# Warning flags
CXXWARN_FLAGS := \
	-W -Wall \
	-Wimplicit \
	-Wswitch \
	-Wformat \
	-Wchar-subscripts \
	-Wparentheses \
	-Wmultichar \
	-Wtrigraphs \
	-Wpointer-arith \
	-Wcast-align \
	-Wreturn-type \
	-Wno-unused-function \
	$(SPACE)
CWARN_FLAGS := $(CXXWARN_FLAGS) \
	-Wstrict-prototypes \
	-Wmissing-prototypes \
	-Wmissing-declarations \
	-Wnested-externs \
	-Wmain \
# architecture flag for nvcc and gcc compilers build
CUBIN_ARCH_FLAG :=
CXX_ARCH_FLAGS  :=
NVCCFLAGS       :=
LIB_ARCH        := $(OSARCH)
# Determining the necessary Cross-Compilation Flags
# 32-bit OS, but we target 64-bit cross compilation
ifeq ($(x86_64),1)
    NVCCFLAGS       += -m64
    LIB_ARCH         = x86_64
    CUDPPLIB_SUFFIX  = x86_64
    ifneq ($(DARWIN),)
         CXX_ARCH_FLAGS += -arch x86_64
    else
         CXX_ARCH_FLAGS += -m64
    endif
else
# 64-bit OS, and we target 32-bit cross compilation
    ifeq ($(i386),1)
        NVCCFLAGS       += -m32
        LIB_ARCH         = i386
        CUDPPLIB_SUFFIX  = i386
        ifneq ($(DARWIN),)
             CXX_ARCH_FLAGS += -arch i386
        else
             CXX_ARCH_FLAGS += -m32
        endif
    else
        ifeq "$(strip $(HP_64))" ""
            LIB_ARCH        = i386
            NVCCFLAGS      += -m32
            ifneq ($(DARWIN),)
            else
            endif
        else
            LIB_ARCH        = x86_64
            NVCCFLAGS      += -m64
            ifneq ($(DARWIN),)
            else
            endif
        endif
    endif
endif
# Compiler-specific flags (by default, we always use sm_10 and sm_20), unless we use the SMVERSION template
GENCODE_SM10 := -gencode=arch=compute_10,code=\"sm_10,compute_10\"
GENCODE_SM20 := -gencode=arch=compute_20,code=\"sm_20,compute_20\"
CXXFLAGS  += $(CXXWARN_FLAGS) $(CXX_ARCH_FLAGS)
CFLAGS    += $(CWARN_FLAGS) $(CXX_ARCH_FLAGS)
LINKFLAGS +=
LINK      += $(LINKFLAGS) $(CXX_ARCH_FLAGS)
# This option for Mac allows CUDA applications to work without requiring to set DYLD_LIBRARY_PATH
ifneq ($(DARWIN),)
   LINK += -Xlinker -rpath $(CUDA_INSTALL_PATH)/lib
endif
# Common flags
COMMONFLAGS += $(INCLUDES) -DUNIX
# Debug/release configuration
ifeq ($(dbg),1)
	COMMONFLAGS += -g
	NVCCFLAGS   += -D_DEBUG
	CXXFLAGS    += -D_DEBUG
	CFLAGS      += -D_DEBUG
	BINSUBDIR   := debug
	LIBSUFFIX   := D
else
	COMMONFLAGS += -O2
	BINSUBDIR   := release
	LIBSUFFIX   :=
	NVCCFLAGS   += --compiler-options -fno-strict-aliasing
	CXXFLAGS    += -fno-strict-aliasing
	CFLAGS      += -fno-strict-aliasing
endif
# architecture flag for cubin build
CUBIN_ARCH_FLAG :=
# OpenGL is used or not (if it is used, then it is necessary to include GLEW)
ifeq ($(USEGLLIB),1)
    ifneq ($(DARWIN),)
        OPENGLLIB := -L/System/Library/Frameworks/OpenGL.framework/Libraries
        OPENGLLIB += -lGL -lGLU $(COMMONDIR)/lib/$(OSLOWER)/libGLEW.a
    else
# this case for linux platforms
	OPENGLLIB := -lGL -lGLU -lX11 -lXi -lXmu
# check if x86_64 flag has been set, otherwise, check HP_64 is i386/x86_64
        ifeq ($(x86_64),1)
	       OPENGLLIB += -lGLEW_x86_64 -L/usr/X11R6/lib64
        else
             ifeq ($(i386),)
	             OPENGLLIB += -lGLEW -L/usr/X11R6/lib
                 else
                 endif
             endif
        endif
# check if i386 flag has been set, otehrwise check HP_64 is i386/x86_64
        ifeq ($(i386),1)
        else
             ifeq ($(x86_64),)
                 else
                 endif
             endif
        endif
    endif
endif
ifeq ($(USEGLUT),1)
    ifneq ($(DARWIN),)
	OPENGLLIB += -framework GLUT
    else
        ifeq ($(x86_64),1)
	     OPENGLLIB += -lglut -L/usr/lib64
        endif
        ifeq ($(i386),1)
        endif
ifeq ($(x86_64),)
            ifeq ($(i386),)
	        OPENGLLIB += -lglut
            endif
        endif
    endif
endif
ifeq ($(USEPARAMGL),1)
	PARAMGLLIB := -lparamgl_$(LIB_ARCH)$(LIBSUFFIX)
endif
ifeq ($(USERENDERCHECKGL),1)
	RENDERCHECKGLLIB := -lrendercheckgl_$(LIB_ARCH)$(LIBSUFFIX)
endif
ifeq ($(USECUDPP), 1)
    CUDPPLIB := -lcudpp_$(CUDPPLIB_SUFFIX)
ifeq ($(emu), 1)
        CUDPPLIB := $(CUDPPLIB)_emu
    endif
endif
ifeq ($(USENVCUVID), 1)
     ifneq ($(DARWIN),)
         NVCUVIDLIB := -L../../common/lib/darwin -lnvcuvid
     endif
endif
# Libs
ifneq ($(DARWIN),)
    LIB       := -L$(CUDA_INSTALL_PATH)/lib -L$(LIBDIR) -L$(COMMONDIR)/lib/$(OSLOWER) -L$(SHAREDDIR)/lib $(NVCUVIDLIB)
else
    ifeq ($(x86_64),1)
       LIB       := -L$(CUDA_INSTALL_PATH)/lib64 -L$(LIBDIR) -L$(COMMONDIR)/lib/$(OSLOWER) -L$(SHAREDDIR)/lib
    else
    endif
  else
    ifeq ($(i386),1)
    else
    endif
  endif
endif
# If dynamically linking to CUDA and CUDART, we exclude the libraries from the LIB
ifeq ($(USECUDADYNLIB),1)
     LIB += ${OPENGLLIB} $(PARAMGLLIB) $(RENDERCHECKGLLIB) $(CUDPPLIB) ${LIB} -ldl -rdynamic
else
# static linking, we will statically link against CUDA and CUDART
  ifeq ($(USEDRVAPI),1)
     LIB += -lcuda   ${OPENGLLIB} $(PARAMGLLIB) $(RENDERCHECKGLLIB) $(CUDPPLIB) ${LIB}
  else
     ifeq ($(emu),1)
         LIB += -lcudartemu
     else
         LIB += -lcudart
     endif
  endif
endif
ifeq ($(USECUFFT),1)
  ifeq ($(emu),1)
    LIB += -lcufftemu
  else
    LIB += -lcufft
  endif
endif
ifeq ($(USECUBLAS),1)
  ifeq ($(emu),1)
    LIB += -lcublasemu
  else
    LIB += -lcublas
  endif
endif
ifeq ($(USECURAND),1)
    LIB += -lcurand
endif
ifeq ($(USECUSPARSE),1)
  LIB += -lcusparse
endif
# Lib/exe configuration
ifneq ($(STATIC_LIB),)
	TARGETDIR := $(LIBDIR)
	TARGET   := $(subst .a,_$(LIB_ARCH)$(LIBSUFFIX).a,$(LIBDIR)/$(STATIC_LIB))
	LINKLINE  = ar rucv $(TARGET) $(OBJS)
else
	ifneq ($(OMIT_CUTIL_LIB),1)
		LIB += -lcutil_$(LIB_ARCH)$(LIBSUFFIX) -lshrutil_$(LIB_ARCH)$(LIBSUFFIX)
	endif
	# Device emulation configuration
	ifeq ($(emu), 1)
		NVCCFLAGS   += -deviceemu
		CUDACCFLAGS +=
		BINSUBDIR   := emu$(BINSUBDIR)
		# consistency, makes developing easier
		CXXFLAGS		+= -D__DEVICE_EMULATION__
		CFLAGS			+= -D__DEVICE_EMULATION__
	endif
	TARGETDIR := $(BINDIR)/$(BINSUBDIR)
	TARGET    := $(TARGETDIR)/$(EXECUTABLE)
	LINKLINE  = $(LINK) -o $(TARGET) $(OBJS) $(LIB)
endif
# check if verbose
ifeq ($(verbose), 1)
	VERBOSE :=
else
	VERBOSE := @
endif
# Check for input flags and set compiler flags appropriately
ifeq ($(fastmath), 1)
	NVCCFLAGS += -use_fast_math
endif
ifeq ($(keep), 1)
	NVCCFLAGS += -keep
	NVCC_KEEP_CLEAN := *.i* *.cubin *.cu.c *.cudafe* *.fatbin.c *.ptx
endif
ifdef maxregisters
	NVCCFLAGS += -maxrregcount $(maxregisters)
endif
ifeq ($(ptxas), 1)
        NVCCFLAGS += --ptxas-options=-v
endif
# Add cudacc flags
NVCCFLAGS += $(CUDACCFLAGS)
# Add common flags
NVCCFLAGS += $(COMMONFLAGS)
CXXFLAGS  += $(COMMONFLAGS)
ifeq ($(nvcc_warn_verbose),1)
	NVCCFLAGS += $(addprefix --compiler-options ,$(CXXWARN_FLAGS))
endif
# Set up object files
OBJDIR := $(ROOTOBJDIR)/$(LIB_ARCH)/$(BINSUBDIR)
OBJS +=  $(patsubst %.cpp,$(OBJDIR)/%.cpp.o,$(notdir $(CCFILES)))
OBJS +=  $(patsubst %.c,$(OBJDIR)/%.c.o,$(notdir $(CFILES)))
OBJS +=  $(patsubst %.cu,$(OBJDIR)/%.cu.o,$(notdir $(CUFILES)))
# Set up cubin output files
CUBINDIR := $(SRCDIR)data
CUBINS +=  $(patsubst %.cu,$(CUBINDIR)/%.cubin,$(notdir $(CUBINFILES)))
# Set up PTX output files
PTXDIR := $(SRCDIR)data
PTXBINS +=  $(patsubst %.cu,$(PTXDIR)/%.ptx,$(notdir $(PTXFILES)))
# Rules
$(OBJDIR)/%.c.o : $(SRCDIR)%.c $(C_DEPS)
	$(VERBOSE)$(CC) $(CFLAGS) -o $@ -c $<
$(OBJDIR)/%.cpp.o : $(SRCDIR)%.cpp $(C_DEPS)
	$(VERBOSE)$(CXX) $(CXXFLAGS) -o $@ -c $<
# Default arch includes gencode for sm_10, sm_20, and other archs from GENCODE_ARCH declared in the makefile
$(OBJDIR)/%.cu.o : $(SRCDIR)%.cu $(CU_DEPS)
	$(VERBOSE)$(NVCC) $(GENCODE_SM10) $(GENCODE_ARCH) $(GENCODE_SM20) $(NVCCFLAGS) $(SMVERSIONFLAGS) -o $@ -c $<
$(CUBINDIR)/%.cubin : $(SRCDIR)%.cu cubindirectory
	$(VERBOSE)$(NVCC) $(GENCODE_SM10) $(GENCODE_ARCH) $(GENCODE_SM20) $(CUBIN_ARCH_FLAG) $(NVCCFLAGS) $(SMVERSIONFLAGS) -o $@ -cubin $<
$(PTXDIR)/%.ptx : $(SRCDIR)%.cu ptxdirectory
	$(VERBOSE)$(NVCC) $(CUBIN_ARCH_FLAG) $(NVCCFLAGS) $(SMVERSIONFLAGS) -o $@ -ptx $<
# The following definition is a template that gets instantiated for each SM
# version (sm_10, sm_13, etc.) stored in SMVERSIONS.  It does 2 things:
# 1. It adds to OBJS a .cu_sm_XX.o for each .cu file it finds in CUFILES_sm_XX.
# 2. It generates a rule for building .cu_sm_XX.o files from the corresponding
#    .cu file.
# The intended use for this is to allow Makefiles that use common.mk to compile
# files to different Compute Capability targets (aka SM arch version).  To do
# so, in the Makefile, list files for each SM arch separately, like so:
# This will be used over the default rule abov
# CUFILES_sm_10 := mycudakernel_sm10.cu app.cu
# CUFILES_sm_12 := anothercudakernel_sm12.cu
define SMVERSION_template
#OBJS += $(patsubst %.cu,$(OBJDIR)/%.cu_$(1).o,$(notdir $(CUFILES_$(1))))
OBJS += $(patsubst %.cu,$(OBJDIR)/%.cu_$(1).o,$(notdir $(CUFILES_sm_$(1))))
$(OBJDIR)/%.cu_$(1).o : $(SRCDIR)%.cu $(CU_DEPS)
#	$(VERBOSE)$(NVCC) -o $$@ -c $$< $(NVCCFLAGS)  $(1)
	$(VERBOSE)$(NVCC) -gencode=arch=compute_$(1),code=\"sm_$(1),compute_$(1)\" $(GENCODE_SM20) -o $$@ -c $$< $(NVCCFLAGS)
endef
# This line invokes the above template for each arch version stored in
# SM_VERSIONS.  The call funtion invokes the template, and the eval
# function interprets it as make commands.
$(foreach smver,$(SM_VERSIONS),$(eval $(call SMVERSION_template,$(smver))))
$(TARGET): makedirectories $(OBJS) $(CUBINS) $(PTXBINS) Makefile
	$(VERBOSE)$(LINKLINE)
cubindirectory:
	$(VERBOSE)mkdir -p $(CUBINDIR)
ptxdirectory:
	$(VERBOSE)mkdir -p $(PTXDIR)
makedirectories:
	$(VERBOSE)mkdir -p $(LIBDIR)
	$(VERBOSE)mkdir -p $(OBJDIR)
	$(VERBOSE)mkdir -p $(TARGETDIR)
tidy :
	$(VERBOSE)find . | egrep "#" | xargs rm -f
	$(VERBOSE)find . | egrep "\~" | xargs rm -f
clean : tidy
	$(VERBOSE)rm -f *.stub.c *.gpu *.cu.cpp *.i *.ii
	$(VERBOSE)rm -f *.cubin *.ptx *.fatbin.c *.hash
	$(VERBOSE)rm -f *.cudafe1.c *.cudafe2.c *.cudafe1.cpp *.cudafe2.cpp
	$(VERBOSE)rm -f $(OBJS)
	$(VERBOSE)rm -f $(CUBINS)
	$(VERBOSE)rm -f $(PTXBINS)
	$(VERBOSE)rm -f $(TARGET)
	$(VERBOSE)rm -f $(NVCC_KEEP_CLEAN)
	$(VERBOSE)rm -f $(ROOTBINDIR)/$(OSLOWER)/$(BINSUBDIR)/*.ppm
	$(VERBOSE)rm -f $(ROOTBINDIR)/$(OSLOWER)/$(BINSUBDIR)/*.pgm
	$(VERBOSE)rm -f $(ROOTBINDIR)/$(OSLOWER)/$(BINSUBDIR)/*.bin
	$(VERBOSE)rm -f $(ROOTBINDIR)/$(OSLOWER)/$(BINSUBDIR)/*.bmp
clobber : clean
	$(VERBOSE)rm -rf $(ROOTOBJDIR)
Note that in the first Makefile, there are also source files specified, and the end result will be an executable file. How could I modify the SDK’s Makefile to only generate an object file from my cuda_kernel.cu file and also what needs to be changed if in this file (cuda_kernel.cu) I need to include some headers from my project?
Hi guys,
// includes
#include <iostream>
	int x0_idx, x1_idx;
	// start timer
    int gates;
    int k=0;
    qbCount -= gates;
		qbCount--;
		blockGrpSize *= 2;
		k++;
	// stop timer
	cudaFree(a_d);
    cudaThreadExit();
extern "C"
# NOTICE TO USER:
CU_DEPS		:= \
CCFILES		:= \
	template_gold.cpp \
# Rules and targets
and common.mk
ifdef cuda-install
endif
# detect OS
ifneq ($(DARWIN),)
endif
SRCDIR     ?=
ROOTDIR    ?= ..
ROOTOBJDIR ?= obj
# Compilers
CXX        := g++ -fPIC
CC         := gcc -fPIC
LINK       := g++ -fPIC
# Includes
# Warning flags
CXXWARN_FLAGS := \
	-W -Wall \
	-Wimplicit \
	-Wswitch \
	-Wformat \
	-Wchar-subscripts \
	-Wparentheses \
	-Wmultichar \
	-Wtrigraphs \
	-Wpointer-arith \
	-Wcast-align \
	-Wreturn-type \
	$(SPACE)
	-Wnested-externs \
	-Wmain \
CUBIN_ARCH_FLAG :=
CXX_ARCH_FLAGS  :=
NVCCFLAGS       :=
ifeq ($(x86_64),1)
    NVCCFLAGS       += -m64
    LIB_ARCH         = x86_64
    ifneq ($(DARWIN),)
    else
    endif
else
    ifeq ($(i386),1)
        NVCCFLAGS       += -m32
        LIB_ARCH         = i386
        ifneq ($(DARWIN),)
        else
        endif
    else
            LIB_ARCH        = i386
            NVCCFLAGS      += -m32
            ifneq ($(DARWIN),)
            else
            endif
        else
            LIB_ARCH        = x86_64
            NVCCFLAGS      += -m64
            ifneq ($(DARWIN),)
            else
            endif
        endif
    endif
endif
LINKFLAGS +=
ifneq ($(DARWIN),)
endif
# Common flags
ifeq ($(dbg),1)
	COMMONFLAGS += -g
	CFLAGS      += -D_DEBUG
	BINSUBDIR   := debug
	LIBSUFFIX   := D
else
	COMMONFLAGS += -O2
	LIBSUFFIX   :=
endif
CUBIN_ARCH_FLAG :=
    ifneq ($(DARWIN),)
    else
        ifeq ($(x86_64),1)
        else
             ifeq ($(i386),)
                 else
                 endif
             endif
        endif
        ifeq ($(i386),1)
        else
             ifeq ($(x86_64),)
                 else
                 endif
             endif
        endif
    endif
endif
ifeq ($(USEGLUT),1)
    ifneq ($(DARWIN),)
    else
        ifeq ($(x86_64),1)
        endif
        ifeq ($(i386),1)
        endif
ifeq ($(x86_64),)
            ifeq ($(i386),)
	        OPENGLLIB += -lglut
            endif
        endif
    endif
endif
endif
endif
ifeq ($(emu), 1)
    endif
endif
     ifneq ($(DARWIN),)
     endif
endif
# Libs
ifneq ($(DARWIN),)
else
    ifeq ($(x86_64),1)
    else
    endif
  else
    ifeq ($(i386),1)
    else
    endif
  endif
endif
else
  else
     ifeq ($(emu),1)
         LIB += -lcudartemu
     else
         LIB += -lcudart
     endif
  endif
endif
  ifeq ($(emu),1)
    LIB += -lcufftemu
  else
    LIB += -lcufft
  endif
endif
  ifeq ($(emu),1)
    LIB += -lcublasemu
  else
    LIB += -lcublas
  endif
endif
    LIB += -lcurand
endif
  LIB += -lcusparse
endif
else
	endif
	ifeq ($(emu), 1)
		CUDACCFLAGS +=
	endif
endif
# check if verbose
	VERBOSE :=
else
	VERBOSE := @
endif
endif
ifeq ($(keep), 1)
	NVCCFLAGS += -keep
endif
ifdef maxregisters
endif
ifeq ($(ptxas), 1)
endif
# Add cudacc flags
# Add common flags
endif
# Rules
#    .cu file.
endef
cubindirectory:
ptxdirectory:
makedirectories:
tidy :
clean : tidy
clobber : clean
I think the SDK makefiles are overly complicated. For a start, you just need a rule for .cu files
%.o : %.cu
        nvcc -arch sm_20 -c -o $@ $<'
(adjust [font=“Courier New”]sm_20[/font] for the compute capability of your device),
add the [font=“Courier New”].o[/font] file from your CUDA file to the list of linked object files, and add libcudart to the linked libraries:
LDFLAGS += -lcudart
EDIT: And remember that the indentation in a Makefile rule has to be a tab, not spaces.
%.o : %.cu
LDFLAGS += -lcudart
@tera
Thanks so much for the reply. Indeed, I find your approach a lot easier.
EDIT: Disregard what I wrote below, I’ve used a much simpler command:
nvcc -arch sm_11 -c -I"/home/[my_username]/NVIDIA_GPU_Computing_SDK/C/common/inc" -o cuda_kernel.o cuda_kernel.cu
[i]So I’ve modified the SDK Makefile to a bare minimum, because I needed to include the headers in the SDK’s common dir. Could you check that the Makefile is correct (ie valid)? I’m not sure if it’s “COMMONDIR ?=” or “COMMONDIR :=”. Anyways, this is my Makefile now to generate an object .o file from my .cu file.
COMMONDIR  ?= /home/glu/NVIDIA_GPU_Computing_SDK/C/common
# Compilers
# Includes
# Rules
%.cu.o : %.cu
	$(NVCC) -arch sm_11 $(INCLUDES) -o $@ -c $<
The problem now is that when I type ‘sudo make’ inside the Makefile’s dir (I’ve made sure it’s executable), I get this error:
make: *** No targets. Stop.
Does anyone has some suggestions?[/i]
@tera
# Compilers
# Includes
# Rules
%.cu.o : %.cu
I have another problem now. I have compiled my .cu file in which resides the kernel and a kernel caller function (“gpucaller”). It compiles fine and I get my .o file. I include this in the Makefile as described by @tera above.
Now from my cpp project, in the source file in which I make the call to “gpucaller”, do I need to also have an include to this .cu file at the top?
Right now I do have an include at the top, and it looks like this:
#include "cuda_kernel.cu"
extern "C"
void gpucaller(opBit *op, quBaseState *q);
But the problem is that when I compile my project (having it’s own Makefile), it doesn’t seem to recognize the cuda “constant” and “global” keywords. I get an error like this: “expected constructor, destructor, or type conversion before ‘void’”.
My project’s Makefile is this one:
# Makefile for QCL
# This file is part of the Quantum Computation Language QCL.
# (c) Copyright by Bernhard Oemer <oemer@tph.tuwien.ac.at> 1998-2006
# This program comes without any warranty; without even the implied
# warranty of merchantability or fitness for any particular purpose.
#      This program is free software under the terms of the
#      GNU General Public Licence (GPL) version 2 or higher
VERSION=0.6.3
# Directory for Standard .qcl files
QCLDIR = /usr/local/lib/qcl
# Path for qcl binaries
QCLBIN = /usr/local/bin
ARCH = `g++ -dumpmachine || echo bin`
# Comment out if you want to compile for a different target architecture
# To build libqc.a, you will also have to edit qc/Makefile!
#ARCH = i686-linux
#ARCHOPT = -m32 -march=i686
# Debugging and optimization options
#DEBUG = -g -pg -DQCL_DEBUG -DQC_DEBUG
#DEBUG = -g -DQCL_DEBUG -DQC_DEBUG
DEBUG = -O2 -g -DQCL_DEBUG -DQC_DEBUG
#DEBUG = -O2
# Plotting support
# Comment out if you don't have GNU libplotter and X
PLOPT = -DQCL_PLOT
PLLIB = -L/usr/X11/lib -lplotter
# Readline support
# Comment out if you don't have GNU readline on your system
# explicit linking against libtermcap or libncurses may be required
RLOPT = -DQCL_USE_READLINE
#RLLIB = -lreadline
RLLIB = -lreadline -lncurses
# Interrupt support
# Comment out if your system doesn't support ANSI C signal handling
IRQOPT = -DQCL_IRQ
# Replace with lex and yacc on non-GNU systems (untested)
LEX = flex
YACC = bison
INSTALL = install
##### You shouldn't have to edit the stuff below #####
DATE = `date +"%y.%m.%d-%H%M"`
QCDIR = qc
QCLIB = $(QCDIR)/libqc.a
QCLINC = lib
#CXX = g++
#CPP = $(CC) -E
CXXFLAGS = -c $(ARCHOPT) -Wall $(DEBUG) $(PLOPT) $(RLOPT) $(IRQOPT) -I$(QCDIR) -DDEF_INCLUDE_PATH="\"$(QCLDIR)\""
LDFLAGS = $(ARCHOPT) -L$(QCDIR) $(DEBUG) $(PLLIB) -lm -lfl -lqc $(RLLIB) -lcudart
FILESCC = $(wildcard *.cc)
FILESH = $(wildcard *.h)
SOURCE = $(FILESCC) $(FILESH) qcl.lex qcl.y Makefile
OBJECTS = types.o syntax.o typcheck.o symbols.o error.o \
          lex.o yacc.o print.o quheap.o extern.o eval.o exec.o \
          parse.o options.o debug.o cond.o dump.o plot.o format.o cuda_kernel.o
all: do-it-all
ifeq (.depend,$(wildcard .depend))
include .depend
do-it-all: build
else
do-it-all: dep
	$(MAKE)
endif
#### Rules for depend
dep: lex.cc yacc.cc yacc.h $(QCLIB)
	for i in *.cc; do \
	  $(CPP) -I$(QCDIR) -MM $$i; \
	done > .depend
lex.cc: qcl.lex yacc.h
	$(LEX) -olex.cc qcl.lex
yacc.cc: qcl.y
	$(YACC) -t -d -o yacc.cc qcl.y
yacc.h: yacc.cc
	mv yacc.*?h yacc.h
$(QCLIB):
	cd $(QCDIR) && $(MAKE) libqc.a
#### Rules for build
build: qcl $(QCLINC)/default.qcl
qcl: $(OBJECTS) qcl.o $(QCLIB)
	$(CXX) $(OBJECTS) qcl.o $(LDFLAGS) -o qcl
$(QCLINC)/default.qcl: extern.cc
	grep "^//!" extern.cc | cut -c5- > $(QCLINC)/default.qcl
checkinst:
	[ -f ./qcl -a -f $(QCLINC)/default.qcl ] || $(MAKE) build
install: checkinst
	$(INSTALL) -m 0755 -d $(QCLBIN) $(QCLDIR)
	$(INSTALL) -m 0755 ./qcl $(QCLBIN)
	$(INSTALL) -m 0644 ./$(QCLINC)/*.qcl $(QCLDIR)
uninstall:
	-rm -f $(QCLBIN)/qcl
	-rm -f $(QCLDIR)/*.qcl
	-rmdir $(QCLDIR)
#### Other Functions
edit:
	nedit $(SOURCE) &
clean:
	rm -f *.o lex.* yacc.*
	cd $(QCDIR) && $(MAKE) clean
clear: clean
	rm -f qcl $(QCLINC)/default.qcl .depend
	cd $(QCDIR) && $(MAKE) clear
dist-src: dep
	mkdir qcl-$(VERSION)
	cp README CHANGES COPYING .depend $(SOURCE) qcl-$(VERSION)
	mkdir qcl-$(VERSION)/qc
	cp qc/Makefile qc/*.h qc/*.cc qcl-$(VERSION)/qc
	cp -r lib qcl-$(VERSION)
	tar czf qcl-$(VERSION).tgz --owner=0 --group=0 qcl-$(VERSION)
	rm -r qcl-$(VERSION)
dist-bin: build
	mkdir qcl-$(VERSION)-$(ARCH)
	cp Makefile README CHANGES COPYING qcl qcl-$(VERSION)-$(ARCH)
	cp -r lib qcl-$(VERSION)-$(ARCH)
	tar czf qcl-$(VERSION)-$(ARCH).tgz --owner=0 --group=0 qcl-$(VERSION)-$(ARCH)
	rm -r qcl-$(VERSION)-$(ARCH)
upload: dist-src
	scp qcl-$(VERSION)*.tgz oemer@tph.tuwien.ac.at:html/tgz
scp: dist-src
	scp qcl-$(VERSION).tgz oemer@tph.tuwien.ac.at:bak/qcl-$(DATE).tgz
extern "C"
# Makefile for QCL
VERSION=0.6.3
#ARCH = i686-linux
#DEBUG = -O2
# Plotting support
PLOPT = -DQCL_PLOT
# Readline support
#RLLIB = -lreadline
# Interrupt support
IRQOPT = -DQCL_IRQ
LEX = flex
YACC = bison
INSTALL = install
QCDIR = qc
QCLINC = lib
#CXX = g++
#CPP = $(CC) -E
all: do-it-all
include .depend
do-it-all: build
else
do-it-all: dep
	$(MAKE)
endif
	for i in *.cc; do \
	done > .depend
yacc.cc: qcl.y
yacc.h: yacc.cc
	mv yacc.*?h yacc.h
$(QCLIB):
checkinst:
install: checkinst
uninstall:
	-rmdir $(QCLDIR)
edit:
	nedit $(SOURCE) &
clean:
clear: clean
dist-src: dep
dist-bin: build
upload: dist-src
scp: dist-src
Don’t include the .cu file anywhere else. Just make a .h header file with the function prototypes and comon data structures and include it into both the .cu and .cpp file.
Did just that. Now my c++ file looks like this (extern.cc):
#include "extern.h"
#include "cuda.h"
ROUTINE(ext_bit) {
    int i;
    quState *qbit;
    PAR_QUSTATE(q,"q");
    opBit *op;
    tComplex I(0,1);
    tComplex sg= inv ? -1 : 1;
    char c=(def->id())[0];
    if(def->id().length()!=1) c='?';
    switch(c) {
        case 'H': op=new opBit(1,1,1,-1,sqrt(0.5)); break;
        case 'X': op=new opBit(0,1,1,0);        break;
        case 'Y': op=new opBit(0,-I,I,0);       break;
        case 'Z': op=new opBit(1,0,0,-1);       break;
        case 'S': op=new opBit(1,0,0,sg*I);     break;
        case 'T': op=new opBit(1,0,0,sqrt(0.5)+sg*sqrt(0.5)*I); break;
        case '?':
        default: EXTERR("unknown single qubit operator "+def->id());
// This is where I call my wrapper function
    // the error that I get is: expected primary-expression before ',' token
    gpucaller(opBit, q);
qcl_delete(op);
    return 0;
The .h file looks like this (cuda.h):
#ifndef _CUDA_H_
#define _CUDA_H_
#include "qustates.h"
void gpucaller(opBit* op, quBaseState* q);
#endif // #ifndef _CUDA_H_
And the .cu file looks like this (cuda_kernel.cu):
/* compiling with:
nvcc -arch sm_11 -c -I"/home/glu/NVIDIA_GPU_Computing_SDK/C/common/inc" -I"." -I"./qc" -I"/usr/local/cuda/include" -o cuda_kernel.o cuda_kernel.cu
// includes
#include "cuda.h"
    int x0_idx, x1_idx;
void gpucaller(opBit* op, quBaseState* q) {
    float** myOpBit = (float**)op->getDeviceReadyOpBit();
    long int N = 1 << q->mapbits();
// start timer
    cudaMemcpy(a_d, q->termsarray, size, cudaMemcpyHostToDevice);
    cudaMemcpy(q->termsarray, a_d, size, cudaMemcpyDeviceToHost);
    // stop timer
    //printf( "GPU Processing time: %f (ms)\n", cutGetTimerValue( timer));
    cudaFree(a_d);
    cudaThreadExit();
I compile the .cu file with the command commented above in the source code.
Now when I compile my project, I get the following error referring to the line in my c++ file (extern.cc) where I call my gpucaller function:
I’ve figured that it’s because the gpucaller‘s arguments’ types aren’t recognized (?), although I’ve included the appropriate headers (operator.h and quStates.h) in my cuda.h file, so I’ve tried compiling again, but this time removing the arguments from the function’s definition and not passing any parameters. It compiles ok, so my hypothesis that the argument types aren’t recognized seems to be correct.
Can anyone help me with this problem?
#include "extern.h"
#include "cuda.h"
ROUTINE(ext_bit) {
    int i;
    quState *qbit;
    PAR_QUSTATE(q,"q");
    opBit *op;
    tComplex I(0,1);
    switch(c) {
        case '?':
qcl_delete(op);
    return 0;
#ifndef _CUDA_H_
#define _CUDA_H_
/* compiling with:
// includes
#include "cuda.h"
    int x0_idx, x1_idx;
// start timer
    // stop timer
    cudaFree(a_d);
    cudaThreadExit();
