Here is the step to make the USB WiFi Dongle chipset rtl8812au (0bda:a811 Realtek Semiconductor Corp.) works on jetson-nano:
Out of box L4T don’t have driver for this rtl8812au chipset. so we need to install the driver manually.
Following command needs to be executed on terminal window:
- sudo apt install git
- sudo apt install dkms
- git clone https://github.com/abperiasamy/rtl8812AU_8821AU_linux.git
- cd rtl8812AU_8821AU_linux
- sudo make -f Makefile.dkms install
- reboot the jetson-nano, your WiFi will be up now!
- Some useful command to check the status f driver and device:
dkms status
iw phy
Great! Thanks for sharing.
Thanks, it worked for me too.
Heads up - the latest commit to the repo in step 3 breaks wifi.
Using an older version (d277c3681ead3ff35169d19fbf119c2d4956b275) will fix it.
to use the older version add the following command between steps 3 and 4.
git checkout d277c3681ead3ff35169d19fbf119c2d4956b275
If you’ve already built and installed the broken driver you’ll have to disable the broken driver before you re-building/installing the working version. There’s probably a better way to do this but what I did was:
cd find / -name "*rtl8812au*"
That should return a .so file somewhere. Delete or rename that file. Then re-start the process of installing with the older version.
the driver works. but I could not see any network.
any idea?
Following @nomidia suggestion, here is the script for installing the driver:
#!/bin/bash
sudo apt-get update && sudo apt-get install dkms
git clone -b v5.6.4.2 https://github.com/aircrack-ng/rtl8812au.git && cd rtl8812au
sed -i 's/CONFIG_PLATFORM_I386_PC = y/CONFIG_PLATFORM_I386_PC = n/g' Makefile
sed -i 's/CONFIG_PLATFORM_ARM_NV_NANO = n/CONFIG_PLATFORM_ARM_NV_NANO = y/g' Makefile
sudo ./dkms-install.sh && sudo reboot
The WiFi module should work flawlessly with newly installed driver.
@yahya_qlue , I’m going to install the driver in my jetson nano 2gb, are these steps applicable now as well…?
@yahya_qlue i can’t find any dkms-install.sh file. How to find that file?
there is no dkms-install.sh in this directory
