Make utility
I recently upgraded to Workstation 7.0-2. But it seems that the make utility was not included?? and now if I type make, the program tells me that make is not recognized as an internal or external command.
Has anyone encountered this and how do I solve this?
Hi gman,
If you’re using Linux, my best guess is that you don’t have ‘/usr/bin’ in your PATH environment. make is a system utility and not shipped with the PGI compilers.
On Windows, if you’ve installed the CYGWIN package that is bundled with the compilers, then ‘/bin’ needs to be in your PATH.
  • Mat
