makefile for compiling multiple kernels
I am relatively new to CUDA, trying to parallelize kind of a large application that consists of multiple .c files. I wrote two kernels so far, but they should be launched from different .c files. I have used a makefile from SDK to test one of the kernels (it worked fine), but having trouble figuring out how to compile this all with a makefile. So file1.cu has file1_kernel, file2.cu has file2_kernel, both file1.cu and file2.cu share .h files and other .c files. How should i modify the makefile?
[codebox]
Add source files here
EXECUTABLE := my_executable
Cuda source files (compiled with cudacc)
CUFILES := file1.cu \
                     file2.cu
#cuda dependency files:
CU_DEPS := file1_kernel.cu \
                       file1.h
#where should file2_kernel go???
C/C++ source files (compiled with gcc / c++)
CFILES := \
    some1.c \
    some2.c  (bla...bla...)
Rules and targets
include …/…/common/common.mk
[/codebox]
any help on this is appreciated…
you can put in CU_DEPS too. In SDK you have a example called dct8x8 with two kernels. Look its makefile. Remember that if you put “make -n” you can see the all lines that makefile will executes.
