Making a 720p live video monitoring
[s]Maybe changing in sender
pt=96
to
payload=96
would help.
[/s]
[EDIT: Sorry, this is wrong. Got confused with your other topic.]
hi all;
I can get the rtsp stream with the following command :
./test-launch “nvcamerasrc ! omxh264enc ! rtph264pay name=pay0 pt=96”
my question is " how can I get the stream with usb device (/dev/video0) ?"
thanks ahead
b/R
Hi DaneLLL;
can you help me solve this issue ,
with usb camera ,I can not get RTSP stream at PC with VLC ?
B/R
Hi lgz3308,
Please put nvvidconv between v4l2src and omxh264enc
gst-launch-1.0 v4l2src device=/dev/video0 ! 'video/x-raw,wodth=640,height=480,format=I420' ! nvvidconv ! 'video/x-raw(memory:NVMM),format=I420,width=640,height=480' ! omxh264enc ! fakesink
Hi DaneLLL,
thank alot ,for you so quick response .
I used above command , the following err be printed , what is the wrong ?
ubuntu@tegra-ubuntu:~$ sudo gst-launch-1.0 v4l2src device=/dev/video1 ! ‘video/x-raw,wodth=640,height=480,format=I420’ ! nvvidconv ! ‘video/x-raw(memory:NVMM),format=I420,width=640,height=480’ ! omxh264enc ! fakesink
Setting pipeline to PAUSED …
Inside NvxLiteH264DecoderLowLatencyInitNvxLiteH264DecoderLowLatencyInit set DPB and MjstreamingInside NvxLiteH265DecoderLowLatencyInitNvxLiteH265DecoderLowLatencyInit set DPB and MjstreamingPipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
New clock: GstSystemClock
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data flow error.
Additional debug info:
gstbasesrc.c(2948): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming task paused, reason not-negotiated (-4)
Execution ended after 0:00:00.599750366
Setting pipeline to READY …
Setting pipeline to NULL …
Freeing pipeline …
BTW: My usb camera dev id is video 1
B/R
Hi lgz3308. please check the format of your usb camera. Look like it is not I420. It probably is UYVY.
yeah ,
I thind this camera output is YUV signal ,mauybe , but how to solve this issue ?
what should I do ,step by step ?
Hi lgz3308,
You can get more information about your camera via v4l2-ctl https://www.mankier.com/1/v4l2-ctl
hi DaneLLL,
with the v4l2-ctl ,I get the following result :
ubuntu@tegra-ubuntu:~/gsteamer_rtsp_server/gst-rtsp-server-1.8.3/examples$ v4l2-ctl -d /dev/video1 --list-formats
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: ‘YUYV’
Name : YUV 4:2:2 (YUYV)
Index       : 1
Pixel Format: 'MJPG' (compressed)
ubuntu@tegra-ubuntu:~/gsteamer_rtsp_server/gst-rtsp-server-1.8.3/examples$ gst-launch-1.0 v4l2src device=/dev/video1 ! ‘video/YUV,wodth=640,height=480,format=YUYV’ ! nvvidconv ! ‘video/x-raw(memory:NVMM),format=MJPG,width=640,height=480’ ! omxh264enc ! fakesink
WARNING: erroneous pipeline: could not link v4l2src0 to nvvconv0
ubuntu@tegra-ubuntu:~/gsteamer_rtsp_server/gst-rtsp-server-1.8.3/examples$ ls /dev |grep video*
video0
video1
what I should to do ,next step ??
Hi lgz3308, nvvidconv on r21,5 does not support YUYV. You may try MJPG
gst-launch-1.0 v4l2src device=/dev/video0 ! 'image/jpeg,width=640,height=480' ! nvjpegdec ! nvvidconv ! 'video/x-raw(memory:NVMM),width=640,height=480,format=I420' ! omxh264enc ! fakesink
ubuntu@tegra-ubuntu:/sys/class/video4linux/video1$ gst-launch-1.0 v4l2src device=/dev/video1 ! ‘image/jpeg,width=640,height=480’ ! nvjpegdec ! nvvidconv ! ‘video/x-raw(memory:NVMM),width=640,height=480,format=I420’ ! omxh264enc ! fakesink
Framerate set to : 30 at NvxVideoEncoderSetParameterNvMMLiteOpen : Block : BlockType = 4
===== MSENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
streaming task paused, reason not-supported (-6)
Execution ended after 0:00:01.629191417
Freeing pipeline …
The usb camra still be no work ??
Probably you should try other usb cameras. The commands we give are verified on Logitech c310/c930.
OH , But this camera is work fine with opencv ,I can open it with opencv normally on TX1 ,with the command : cap = cv2.VideoCapture( 1)
Hi lgz3308,
Please try the following command to see which one shows video preview:
export DISPLAY=:0
gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,format=GRAY8 ! xvimagesink
gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,format=YV12 ! xvimagesink
gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,format=I420 ! xvimagesink
gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,format=UYVY ! xvimagesink
gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,format=YUY2 ! xvimagesink
gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,format=YVYU ! xvimagesink
Hi daneLLL
thanks alot
with this cmd , the usb camera is work fine
You should be able to run
gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,format=YUY2,width=640,height=480 ! videoconvert ! video/x-raw,format=I420 ! omxh264enc ! fakesink
hi DaneLLL ,
when I do the above cmd :
buntu@tegra-ubuntu:~$ gst-launch-1.0 v4l2src device=/dev/video1 ! video/x-raw,format=YUY2,width=640,height=480 ! videoconvert ! video/x-raw,format=I420 ! omxh264enc ! fakesink
===== MSENC =====
===== MSENC blits (mode: 1) into tiled surfaces =====
no shell prompt "#"return, what I should do next ?
Hi lgz3308,
./test-launch "v4l2src device=/dev/video1 ! video/x-raw,format=YUY2,width=640,height=480 ! videoconvert ! video/x-raw,format=I420 ! omxh264enc ! rtph264pay name=pay0 pt=96"
Ok , thanks alot , Dear DaneLLL
During transcode , There are so many trap!!!
It is work fine ,I can get RTSP stream from my PC!
thanks for you Patience ,again ! :)
B/R
Hi DaneLLL:
Today , I buy one logitech C310 camera as you suggested with the following cmd ,I can get rtsp stream ,but 2 questions confueed me ,
1> How I can get the 720P stream ,instead 640*480 ??
2> why I can get the stream only 1 PC in the meanwhile , I need muti_PC terminal. what I need to do more ??
B/R
