Making a Mesh invisible in Rendering while keeping it detectable by RTX LiDAR in Isaac Sim 6.0.0
I am sharing this information, rather than asking a question, because the issue raised in How can I make a mesh invisible in rendering while keeping it detectable by RTX LiDAR in Isaac Sim 6.0? was not properly answered at the time (it suggests changing the mesh opacity, which does not work for this use case). I wanted to put out a working solution for anyone trying to combine a photorealistic 3DGS scene with RTX LiDAR in Isaac Sim 6.0.0.
You can achieve proper integration using a USD proxy workflow. I have also attached screenshots of the workflow below.
Given:
  • A 3DGS model for photorealistic rendering.
  • A separate mesh (.fbx or .ply) for RTX LiDAR detection and collision (You can link up to 4 individual meshes to a single Gauss volume).
Workflow:
  1. In the Stage window, select the 3D Gaussian Splatting volume prim (/World/gauss/gauss).
  2. In the property panel, under Raw USD Properties, assign the proxy targets. Click the “Add Target…” button, and select your separate mesh of type Mesh (e.g., /World/mesh_edited/mesh_) from the popup.
Result:
  1. The 3DGS model is visible in the viewport and camera (the USDZ looks photorealistic in the main camera viewport).
  2. The visual mesh is hidden from rendering.
  3. RTX LiDAR still correctly detects the structural proxy mesh, showing accurate point cloud and distance without a visible white mesh blocking the appearance of the 3DGS model.
Environment:
  • Isaac Sim 6.0.0
  • RTX LiDAR
I hope this would be helpful for someone!
Thank you for sharing and validating this method with the community.
This is very helpful for users combining 3DGS scenes with RTX LiDAR in Isaac Sim 6.0.0. We appreciate the clear steps and screenshots!
