Making & burning image file for emmc
i have a jetson orin (with emmc as main disk) works well and i want to clone whole system into an image and burn it to another board. Could not find any instruction for this case (most are with sd card).
appreciate any advice/opinion
Last time I attempted something like this was in a Xavier AGX. Using the flash.sh script provided with the JetPack installation on your PC may be possible to perform what you need with the Orin NX.
sudo ./flash.sh -r -k APP -G backup.img jetson-orin-nx-devkit mmcblk0p1
To flash the backup in other system you could try:
mv bootloader/system.img bootloader/system_original.img
cp backup.img bootloader/system.img
sudo ./flash.sh -r -k APP jetson-orin-nx-devkit mmcblk0p1
Hope this info helps.
Jafet Chaves,
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com/
Website: www.ridgerun.com
as you use eMMC as the main storage, you may just follow steps provided by @jchaves,
or if you switch to an NVMe drive, refer to Linux_for_Tegra/tools/backup_restore/README_backup_restore.txt for instructions.
