Hi
The version of my PGI compiler is 16.4, and what method can be used to make sure that my compilation was successful?
Thank you![/b]
Properly compiled files result in object files.
pgfortran -c foo.f
should produce foo.o, if successful.
file foo.o
should indicate it is an object file.
pgfortran -o foo foo.f90
or
pgcc -o hello hello.c
are successful if they create the executable (foo,hello) and the
programs run.
So, compile a program and run it and if it works, compilation
was successful.
dave
