Hi Hemal,
Thanks for clarifying, I was able to use and modify the GpuImageBuilderNode. I implemented a very basic queue in the GpuImageBuilderNode that would first queue up 300 frames, and then start publishing at a rate of 33 ms. I did this so that I would have a steady rate of publishing NitrosImages into the RectifyNode then eventually into the ESS node.
We had found that the ros benchmarking examples contained queueing of the NitrosImage types before publishing them into the Node under test (ESS in my case), so I thought doing the same would help resolve the bottleneck issues, but the ESS node still seems to choke after some time.
Here is my diff on the GpuImageBuilderNode. Can you share any insight on what could be causing a throughput bottleneck still, even though the NitrosImages are queued and fed at a steady rate?
diff --git a/isaac_ros_managed_nitros_examples/custom_nitros_image/include/custom_nitros_image/gpu_image_builder_node.hpp b/isaac_ros_managed_nitros_examples/custom_nitros_image/include/custom_nitros_image/gpu_image_builder_node.hpp
index 6a93138..eb06568 100644
--- a/isaac_ros_managed_nitros_examples/custom_nitros_image/include/custom_nitros_image/gpu_image_builder_node.hpp
+++ b/isaac_ros_managed_nitros_examples/custom_nitros_image/include/custom_nitros_image/gpu_image_builder_node.hpp
@@ -27,6 +27,8 @@
#include "sensor_msgs/msg/image.hpp"
#include "isaac_ros_nitros_image_type/nitros_image.hpp"
+#include <queue>
namespace custom_nitros_image
@@ -46,6 +48,12 @@ private:
// Publisher for output NitrosImage messages
std::shared_ptr<nvidia::isaac_ros::nitros::ManagedNitrosPublisher<
nvidia::isaac_ros::nitros::NitrosImage>> nitros_pub_;
+ // Queue for Nitros Images
+ std::queue<nvidia::isaac_ros::nitros::NitrosImage> myQueue;
+ void publishImage();
+ rclcpp::TimerBase::SharedPtr timer;
+ bool blockPublishing;
} // namespace custom_nitros_image
diff --git a/isaac_ros_managed_nitros_examples/custom_nitros_image/src/gpu_image_builder_node.cpp b/isaac_ros_managed_nitros_examples/custom_nitros_image/src/gpu_image_builder_node.cpp
index 16a6106..05630c9 100644
--- a/isaac_ros_managed_nitros_examples/custom_nitros_image/src/gpu_image_builder_node.cpp
+++ b/isaac_ros_managed_nitros_examples/custom_nitros_image/src/gpu_image_builder_node.cpp
@@ -22,6 +22,7 @@
#include "isaac_ros_nitros_image_type/nitros_image_builder.hpp"
#include "sensor_msgs/image_encodings.hpp"
@@ -33,10 +34,30 @@ GpuImageBuilderNode::GpuImageBuilderNode(const rclcpp::NodeOptions options)
nitros_pub_{std::make_shared<nvidia::isaac_ros::nitros::ManagedNitrosPublisher<
nvidia::isaac_ros::nitros::NitrosImage>>(
this, "gpu_image",
- nvidia::isaac_ros::nitros::nitros_image_rgb8_t::supported_type_name)} {}
+ nvidia::isaac_ros::nitros::nitros_image_rgb8_t::supported_type_name)},
+ blockPublishing(true) {
+ // Create a timer to publish the Image message every 33 milliseconds
+ timer = this->create_wall_timer(std::chrono::milliseconds(33),
+ std::bind(&GpuImageBuilderNode::publishImage, this));
GpuImageBuilderNode::~GpuImageBuilderNode() = default;
+void GpuImageBuilderNode::publishImage(){
+ if(blockPublishing)
+ return;
+ if(myQueue.size() == 0){
+ RCLCPP_INFO(this->get_logger(), "Queue is empty, cannot publish!");
+ }else{
+ RCLCPP_INFO(this->get_logger(), "Publishing image.. Current queue size: %i", myQueue.size());
+ nitros_pub_->publish(myQueue.front());
+ myQueue.pop();
void GpuImageBuilderNode::InputCallback(const sensor_msgs::msg::Image::SharedPtr msg)
// Get size of image
@@ -64,8 +85,16 @@ void GpuImageBuilderNode::InputCallback(const sensor_msgs::msg::Image::SharedPtr
.WithGpuData(buffer)
.Build();
- nitros_pub_->publish(nitros_image);
- RCLCPP_INFO(this->get_logger(), "Sent CUDA buffer with memory at: %p", buffer);
+ myQueue.push(nitros_image);
+ RCLCPP_INFO(this->get_logger(), "Queued NitrosImage with CUDA buffer memory at: %p", buffer);
+ if(myQueue.size() == 300){
+ RCLCPP_INFO(this->get_logger(), "Queue is now full! Unblock publishing!");
+ blockPublishing = false;
+ // nitros_pub_->publish(nitros_image);
+ // RCLCPP_INFO(this->get_logger(), "Sent CUDA buffer with memory at: %p", buffer);
