Managed to flash jetson xavier nx custom board with JP462 not JP502
Do this solution work for you?
You can also change boot order at boot time by pressing escape to enter UEFI GUI menu.
For the next release, we will change the boot order at flash time so you don’t have to change it yourself.
I had too much things to do to retest.
I will perhaps have time tomorrow.
Do you know when 5.1 should be out like roadmap said?
I took time to retest without any luck.
size of your nvme drive = 128GB
128035676160
so I indicated : num_sectors 250069680
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c ./tools/kernel_flash/flash_l4t_external.xml -S 118GiB --erase-all --network usb0 --showlogs jetson-xavier-nx-devkit nvme0n1p1
So what happens? Does it not boot? Or does it not flash?
Actually I think you just need to run
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c ./tools/kernel_flash/flash_l4t_external.xml --erase-all --network usb0 --showlogs jetson-xavier-nx-devkit nvme0n1p1
Without any changes to to the xml file.
it fails on flash.idx not found !
so now I redownload from scratch tar.bz2
pfiou, I’m fed up with this !
generating system.img for booting…
Making system.img…
/tmp/tmp.Rb58x344nc/boot/extlinux/extlinux.conf is not found, exiting…
Error: failed to generate images
Cleaning up…
gagi@gagi-MXC062:~/nvidia/nvidia_sdk/alamain/Linux_for_Tegra$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c ./tools/kernel_flash/flash_l4t_external.xml -S 118GiB --erase-all --network usb0 --showlogs jetson-xavier-nx-devkit nvme0n1p1
I think you forget to do:
sudo ./apply_binaries.sh
Also, I think you just need to run
yes just found this step forgoten …
Waiting for target to boot-up…
Waiting for device to expose ssh …RTNETLINK answers: File exists
Waiting for device to expose ssh …Run command: flash on fc00:1:1:0::2
SSH ready
blockdev: cannot open /dev/mmcblk0boot0: No such file or directory
[ 0]: l4t_flash_from_kernel: Starting to create gpt for emmc
Active index file is /mnt/internal/flash.idx
Number of lines is 64
max_index=63
writing item=43, 6:0:primary_gpt, 512, 19968, gpt_primary_6_0.bin, 16896, fixed--0, 218e106bc3f95293c574aebcb980f0798d8a759f
Error: Could not stat device /dev/mmcblk0 - No such file or directory.
Flash failure
Cleaning up…
gagi@gagi-MXC062:~/nvidia/nvidia_sdk/alamain/Linux_for_Tegra$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c ./tools/kernel_flash/flash_l4t_external.xml --erase-all --network usb0 --showlogs jetson-xavier-nx-devkit nvme0n1p1
Oh this one have no sd card right
Yes lhoang,
those carrier boards clones don’t have sd card like the real dev kit does I think.
you got a solution to workaround this?
thanks in advance
You can just use
sudo ./nvsdkmanager_flash.sh --storage nvme0n1p1
Edit: Oh wait you use a custom carrier board, you probably have to use
sudo NO_ROOTFS=1 ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml --showlogs --network usb0 jetson-xavier-nx-devkit-qspi internal
then.
The reason to use this command
overwrite the sdcard / emmc with a boot partition to use nvme0n1p1 as rootfs so you don’t have to manually change UEFI boot order using GUI or efibootmgr
just launched this command, waiting …
if the first command not work
→ this one reboot and nvme continuously green like it’s hanging
Copied 16896 bytes from /mnt/internal/gpt_secondary_3_0.bin to address 0x01ffbe00 in flash
[ 240]: l4t_flash_from_kernel: Successfully flash the qspi
[ 240]: l4t_flash_from_kernel: Flashing success
[ 240]: l4t_flash_from_kernel: The device is going to reboot in 5 seconds…
Running in chroot, ignoring request.
[ 245]: l4t_flash_from_kernel: The device size indicated in the partition layout xml is smaller than the actual size. This utility will try to fix the GPT.
Flash is successful
Reboot device
Cleaning up…
Log is saved to Linux_for_Tegra/initrdlog/flash_2-1.4_0_20220929-221804.log
now trying last command …
same again with :
[ 239]: l4t_flash_from_kernel: Successfully flash the qspi
[ 239]: l4t_flash_from_kernel: Flashing success
[ 239]: l4t_flash_from_kernel: The device is going to reboot in 5 seconds…
Flash is successful
Reboot device
Cleaning up…
Log is saved to Linux_for_Tegra/initrdlog/flash_2-1.4_0_20220929-223032.log
flash_2-1.4_0_20220929-221804.log (57.8 KB)
flash_2-1.4_0_20220929-223032.log (57.8 KB)
managed to have something trying to boot with this command :
sudo NO_ROOTFS=1 ./tools/kernel_flash/l4t_initrdt-flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml --erase-all --showlogs --network usb0 jetson-xavier-nx-devkit-emmc nvme0n1p1
now I have uefi, tried to force boot order to nvme and seems it cannot find the UUID.
attached is a screenshot and latest log
IMG_6652
flash_2-1.4_0_20220929-231317.log (71.8 KB)
Ok I see your device is an nx devkit with emmc. I though your device is a nx devkit sd card with no emmc and no sd card. So the command you should use is:
sudo ./tools/kernel_flash/l4t_initrdt-flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml --erase-all --showlogs --network usb0 jetson-xavier-nx-devkit-emmc nvme0n1p1
