I want to process stream from web camera with my Jetson Nano and i faced problem during streaming from local network. Stream freezes for some seconds every 1-2 second of normal streaming.
Although when i plug camera directly into jetson, it works just fine.
I tried
gst-launch-1.0 playbin uri=rtsp://<cam_ip>
and modified deepstream-app (i cut off pgie and osd plugins as i don’t need them to simply display video stream)
deepstream-test3-app rtsp://<cam_ip>
but result is the same.
Also i have another web camera which is identical to the first one and it works fine both through local network and direct connection
I guess the problem may be caused by network connection or camera itself.
My question is what tools and options of gstreamer/deepstream i can use to localize problem and manage unstable stream for smooth displaying?
