Dear all,
I’m wondering if you have some hints for the fan control (nv_fanctrl.sh) for DRIVE software version 10?
After booting our system the fans start turning at high speed (-> loud noise). I’ve seen already the post about the fan controller script “loud fan noise after upgrading to software 9.0” but that is not really helping
General questrion: What should users do if they have a platform with dGPU (the described fix should only be applied to systems without dGPU if I understand correctly?)
Do you have description of the fan control parameters and maybe also a example description for example:
- Where can we look up the pwm numbers ?
- Which SOC should be server and which one client?
- What is meant by “Apply acoustic offset”?
- What is meant by “Set as member of remote SOC”, “Set as SOC A” etc. ? → Would that mean we need to set parameters for Tegra A and Tegra B and this CVM?
- Apply dGPU temperature and Fan curve → so there is a temperature related fan curve included, then I’m wondering why our system is so loud in idle state in a cool labaratory (enviromental temperature about 23° Celsius)?
- And what if we accidentally incorrectly set a fan control parameter: does the system have a thermal protection (i.e. shutdown) or do we have to fear a system damage during hot summer times?
Or a a more user friendly script (from my point of view): I just want to keep the noise / fan speed low and it should raise automatically if required. Frankly speaking I don’t care so much about setting every single bit of the system as long it is silent and a thermal protection is included which raises the fan speed if required (keeping the temperature of all cores/system safe). And if possible also preventing a continous change between up / down spinning of the fans (hysteresis) would be also appreciated…
Hardware Platform: DRIVE AGX Pegasus™ Developer Kit
Software Version: Example: DRIVE Software 10
Host Machine Version: native Ubuntu 18.04
SDK Manager Version: 1.0.1.5538
Thank you a lot!
