• Jetson Xavier
• DeepStream 6.0.0
• JetPack 4.6.2
• TensorRT 8.0.1
**• Questions **
I need to use an external object detector instead of the PGIE object detector, i.e. I will receive object coordinates from an outside app and parse them. Now I need to somehow feed these object coordinates as input to the nv-infer classifier module. In my understanding I need to add a probe upstream and use nvds_add_obj_meta_to_frame to manually add the metadatas, does it seem feasible to you with multiple input streams and multiple object? Has this ever be done before?
Thank you very much,
Paul Doucet
