This appears to still be an issue; I’m on Windows 10 (1809, 17763.437) and this happens multiple times a day. I currently have the GeForce Game Ready Driver (419.67) installed. My card is a GTX 1060 (3GB). Machine is a Intel Core i7-7700 CPU @ 3.60GHz. Here’s my most recent mini dump:
Microsoft (R) Windows Debugger Version 10.0.18317.1001 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump
Loading Dump File [C:\Windows\Minidump\040919-8109-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: srv*
Executable search path is:
Windows 10 Kernel Version 17763 MP (8 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 17763.1.amd64fre.rs5_release.180914-1434
Machine Name:
Kernel base = 0xfffff80755015000 PsLoadedModuleList = 0xfffff807
55430790
Debug session time: Tue Apr 9 12:31:50.653 2019 (UTC - 5:00)
System Uptime: 0 days 18:52:38.375
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
For analysis of this file, run !analyze -v
nt!KeBugCheckEx:
fffff807551c86a0 48894c2408 mov qword ptr [rsp+8],rcx ss:0018:fffff807
570d0310=0000000000000133
0: kd> !analyze -v
DPC_WATCHDOG_VIOLATION (133)
The DPC watchdog detected a prolonged run time at an IRQL of DISPATCH_LEVEL
or above.
Arguments:
Arg1: 0000000000000001, The system cumulatively spent an extended period of time at
DISPATCH_LEVEL or above. The offending component can usually be
identified with a stack trace.
Arg2: 0000000000001e00, The watchdog period.
Arg3: fffff80755557380, cast to nt!DPC_WATCHDOG_GLOBAL_TRIAGE_BLOCK, which contains
additional information regarding the cumulative timeout
Arg4: 0000000000000000
Debugging Details:
KEY_VALUES_STRING: 1
PROCESSES_ANALYSIS: 1
SERVICE_ANALYSIS: 1
STACKHASH_ANALYSIS: 1
TIMELINE_ANALYSIS: 1
DUMP_CLASS: 1
DUMP_QUALIFIER: 400
BUILD_VERSION_STRING: 17763.1.amd64fre.rs5_release.180914-1434
SYSTEM_MANUFACTURER: System manufacturer
SYSTEM_PRODUCT_NAME: System Product Name
SYSTEM_SKU: SKU
SYSTEM_VERSION: System Version
BIOS_VENDOR: American Megatrends Inc.
BIOS_VERSION: 3402
BIOS_DATE: 07/05/2017
BASEBOARD_MANUFACTURER: Asus
BASEBOARD_PRODUCT: H110-PLUS
BASEBOARD_VERSION: Rev X.0x
DUMP_TYPE: 2
BUGCHECK_P1: 1
BUGCHECK_P2: 1e00
BUGCHECK_P3: fffff80755557380
BUGCHECK_P4: 0
DPC_TIMEOUT_TYPE: DPC_QUEUE_EXECUTION_TIMEOUT_EXCEEDED
CPU_COUNT: 8
CPU_MHZ: e10
CPU_VENDOR: GenuineIntel
CPU_FAMILY: 6
CPU_MODEL: 9e
CPU_STEPPING: 9
CPU_MICROCODE: 6,9e,9,0 (F,M,S,R) SIG: 84’00000000 (cache) 84’00000000 (init)
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXPNP: 1 (!blackboxpnp)
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT
BUGCHECK_STR: 0x133
PROCESS_NAME: System
CURRENT_IRQL: d
ANALYSIS_SESSION_HOST: DESKTOP-L93EKRH
ANALYSIS_SESSION_TIME: 04-09-2019 20:10:07.0748
ANALYSIS_VERSION: 10.0.18317.1001 amd64fre
LAST_CONTROL_TRANSFER: from fffff80755241a83 to fffff807551c86a0
STACK_TEXT:
fffff807570d0308 fffff807
55241a83 : 0000000000000133 00000000
00000001 0000000000001e00 fffff807
55557380 : nt!KeBugCheckEx
fffff807570d0310 fffff807
550f98bf : 0000be3f046c70f2 fffff807
532c2180 0000000000000286 00000000
00425d98 : nt!KeAccumulateTicks+0x144b53
fffff807570d0370 fffff807
55a8647c : 0000000000000000 fffff807
55aeb750 fffff807570d07e0 fffff807
55aeb800 : nt!KeClockInterruptNotify+0xcf
fffff807570d0690 fffff807
55148195 : fffff80755aeb750 fffff807
55148195 fffff80755aeb750 fffff807
532c2180 : hal!HalpTimerClockIpiRoutine+0x1c
fffff807570d06c0 fffff807
551ca09a : fffff807570d07e0 fffff807
55aeb750 0000000000000000 fffff807
551c4ab0 : nt!KiCallInterruptServiceRoutine+0xa5
fffff807570d0710 fffff807
551ca5e7 : 0000000000000007 fffff800
8ef4a734 fffff807570d0b30 fffff807
551c4ab0 : nt!KiInterruptSubDispatchNoLockNoEtw+0xfa
fffff807570d0760 fffff800
8ef2a3a5 : fffff8008ef4d9e0 ffffe488
a6c6a000 0000000000000000 00000000
00000000 : nt!KiInterruptDispatchNoLockNoEtw+0x37
fffff807570d08f8 fffff800
8ef4d9e0 : ffffe488a6c6a000 00000000
00000000 0000000000000000 fffff800
8efc6ea0 : nvlddmkm+0x1ea3a5
fffff807570d0900 ffffe488
a6c6a000 : 0000000000000000 00000000
00000000 fffff8008efc6ea0 ffffe488
00000020 : nvlddmkm+0x20d9e0
fffff807570d0908 00000000
00000000 : 0000000000000000 fffff800
8efc6ea0 ffffe48800000020 fffff807
570d0940 : 0xffffe488`a6c6a000
THREAD_SHA1_HASH_MOD_FUNC: 588f764390cf3a7f40526e2ad7327176945e52e0
THREAD_SHA1_HASH_MOD_FUNC_OFFSET: 5d43bf8a09a8a4779f38975c02632def96effb3a
THREAD_SHA1_HASH_MOD: b65638c546229c8b9c3693c2a82ed471ad9bee32
FOLLOWUP_IP:
nvlddmkm+1ea3a5
fffff800`8ef2a3a5 c3 ret
FAULT_INSTR_CODE: 8accccc3
SYMBOL_STACK_INDEX: 7
SYMBOL_NAME: nvlddmkm+1ea3a5
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nvlddmkm
IMAGE_NAME: nvlddmkm.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 5c8de56a
STACK_COMMAND: .thread ; .cxr ; kb
BUCKET_ID_FUNC_OFFSET: 1ea3a5
FAILURE_BUCKET_ID: 0x133_ISR_nvlddmkm!unknown_function
PRIMARY_PROBLEM_CLASS: 0x133_ISR_nvlddmkm!unknown_function
TARGET_TIME: 2019-04-09T17:31:50.000Z
OSBUILD: 17763
OSSERVICEPACK: 404
SERVICEPACK_NUMBER: 0
OS_REVISION: 0
SUITE_MASK: 272
PRODUCT_TYPE: 1
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
OSEDITION: Windows 10 WinNt TerminalServer SingleUserTS
OS_LOCALE:
USER_LCID: 0
OSBUILD_TIMESTAMP: 2022-05-13 04:29:43
BUILDDATESTAMP_STR: 180914-1434
BUILDLAB_STR: rs5_release
BUILDOSVER_STR: 10.0.17763.1.amd64fre.rs5_release.180914-1434
ANALYSIS_SESSION_ELAPSED_TIME: 16d36
ANALYSIS_SOURCE: KM
FAILURE_ID_HASH_STRING: km:0x133_isr_nvlddmkm!unknown_function
FAILURE_ID_HASH: {f97493a5-ea2b-23ca-a808-8602773c2a86}
Followup: MachineOwner
40919-8109-01.dmp]
Machine Name:
Kernel base = 0xfffff807`55015000 PsLoadedModuleList = 0xfffff807`55430790
nt!KeBugCheckEx:
fffff807`551c86a0 48894c2408 mov qword ptr [rsp+8],rcx ss:0018:fffff807`570d0310=0000000000000133
0: kd> !analyze -v
* Bugcheck Analysis *
or above.
Arguments:
Debugging Details:
SERVICE_ANALYSIS: 1
DUMP_CLASS: 1
DUMP_QUALIFIER: 400
SYSTEM_SKU: SKU
BIOS_VERSION: 3402
DUMP_TYPE: 2
BUGCHECK_P1: 1
BUGCHECK_P2: 1e00
BUGCHECK_P4: 0
CPU_COUNT: 8
CPU_MHZ: e10
CPU_FAMILY: 6
CPU_MODEL: 9e
CPU_STEPPING: 9
CPU_MICROCODE: 6,9e,9,0 (F,M,S,R) SIG: 84'00000000 (cache) 84'00000000 (init)
BUGCHECK_STR: 0x133
CURRENT_IRQL: d
STACK_TEXT:
fffff807`570d0308 fffff807`55241a83 : 00000000`00000133 00000000`00000001 00000000`00001e00 fffff807`55557380 : nt!KeBugCheckEx
fffff807`570d0310 fffff807`550f98bf : 0000be3f`046c70f2 fffff807`532c2180 00000000`00000286 00000000`00425d98 : nt!KeAccumulateTicks+0x144b53
fffff807`570d0370 fffff807`55a8647c : 00000000`00000000 fffff807`55aeb750 fffff807`570d07e0 fffff807`55aeb800 : nt!KeClockInterruptNotify+0xcf
fffff807`570d0690 fffff807`55148195 : fffff807`55aeb750 fffff807`55148195 fffff807`55aeb750 fffff807`532c2180 : hal!HalpTimerClockIpiRoutine+0x1c
fffff807`570d06c0 fffff807`551ca09a : fffff807`570d07e0 fffff807`55aeb750 00000000`00000000 fffff807`551c4ab0 : nt!KiCallInterruptServiceRoutine+0xa5
fffff807`570d0710 fffff807`551ca5e7 : 00000000`00000007 fffff800`8ef4a734 fffff807`570d0b30 fffff807`551c4ab0 : nt!KiInterruptSubDispatchNoLockNoEtw+0xfa
fffff807`570d0760 fffff800`8ef2a3a5 : fffff800`8ef4d9e0 ffffe488`a6c6a000 00000000`00000000 00000000`00000000 : nt!KiInterruptDispatchNoLockNoEtw+0x37
fffff807`570d08f8 fffff800`8ef4d9e0 : ffffe488`a6c6a000 00000000`00000000 00000000`00000000 fffff800`8efc6ea0 : nvlddmkm+0x1ea3a5
fffff807`570d0900 ffffe488`a6c6a000 : 00000000`00000000 00000000`00000000 fffff800`8efc6ea0 ffffe488`00000020 : nvlddmkm+0x20d9e0
fffff807`570d0908 00000000`00000000 : 00000000`00000000 fffff800`8efc6ea0 ffffe488`00000020 fffff807`570d0940 : 0xffffe488`a6c6a000
FOLLOWUP_IP:
nvlddmkm+1ea3a5
OSBUILD: 17763
OSSERVICEPACK: 404
OS_REVISION: 0
SUITE_MASK: 272
PRODUCT_TYPE: 1
OSNAME: Windows 10
OS_LOCALE:
USER_LCID: 0
ANALYSIS_SOURCE: KM
