mapping I2C name in dts with I2C device node
I2C buses of TX1 show as “/dev/i2c-0” ~ “/dev/i2c-6” but in dts they are named as “i2c@7000c400”, “i2c@546c0000”, …
What is mapping between I2C name and device node?
Thanks in advance.
In the Technical Reference Manual (TRM) there are multiple interchangeable controllers of any given type. The “@7000c400” is the TRM’s listing of an i2c controller reached at that base address; the controllers appear in order in the TRM, so i2c-0 would be the first controller’s base address. To see which addresses are listed, the TRM is found at:
https://developer.nvidia.com/embedded/dlc/tegra-x1-technical-reference-manual
Or search under Tegra X1 here:
https://developer.nvidia.com/embedded/downloads
That’s exactly what I was looking for.
gen1 i2c number ?
