Hi all,
I just installed Driveworks 1.2.
I’m working on HD maps and Driveworks SDK Reference describes a usefull tool(maptool_here_to_dw_maps) to export HERE HD map to Driveworks maps file.
The problem is that I cannot find maptool_here_to_dw_maps file on my Driworks installation.
It should be located under /<installation_folder>/driveworks-1.2/tools/maps.
Is there something wrong with my installation?
Thank you for the help
Salvatore
Dear salvatore,
Thank you for letting us know this issue. We are looking into it and update you
Dear salvatore,
Are you referring to file:///usr/local/driveworks-1.2/doc/nvdwx_html/dwx_map_data_tools.html on your PX2?
I don’t find maptool_here_to_dw_maps tool in the description.
Dear SivaRamaKrishna,
thank you for your reply.
I’m referring to file:///usr/local/driveworks-1.2/doc/nvdwx_html/dwx_maptool_here_to_dw_maps.html that I can find on my host pc.
In the previous driveworks release(0.6), mapdata_tool allowed to perform a limitated HERE HD map download and processing.
Reading the dwx_maptool_here_to_dw_maps.html file, it seems that the HERE support is still mantained in current driveworks release. Is it correct?
Thanks again
Salvatore
Dear Salvatore,
maptool_here_to_dw_maps is not intended for DrivePX2. It is available on Drive AGX Xavier. You can load your custom map data in DW. Please check file:///usr/local/driveworks-1.2/doc/nvdwx_html/maps_usecase7.html for more details
