I installed DRIVE s/w 10 on Ubuntu 18.04 successfully. I manually constructed a tiny test map which has just one road segment with just 1 lane. I then overwrite the sample map (map_tomtom_280_92_101_85.xml) with this test map, since maptool_inspection does not work with --map cmdline argument (A separate message I posted in this forum). maptool_inspection just crashes when it tries to load the test map:
[01-12-2020 09:25:11] Platform: Detected Generic x86 Platform
[01-12-2020 09:25:11] TimeSource: monotonic epoch time offset is 1606756865703923
[01-12-2020 09:25:11] Platform: number of GPU devices detected 1
[01-12-2020 09:25:11] Platform: currently selected GPU device discrete ID 0
[01-12-2020 09:25:11] SDK: Resources mounted from …/…/data/
[01-12-2020 09:25:11] Initialize DriveWorks SDK v2.2.3136
[01-12-2020 09:25:11] Release build with GNU 7.4.0 from heads/buildbrain-branch-0-gca7b4b26e65
[01-12-2020 09:25:11] Initialize DriveWorks VisualizationSDK v2.2.3136
[01-12-2020 09:25:11] Initialize DriveWorksGL SDK v2.2.3136
[01-12-2020 09:25:11] GL-SDK: initialize OpenGL
[01-12-2020 09:25:11] Maps: Reading map data from “…/…/data/hdmaps/map_tomtom_280_92_101_85.xml” …Segmentation fault (core dumped)
I have attached the test map file. I have to rename it to .txt file in order to bypass the forum upload file extension restriction. Please rename it back to .xml file upon downloading.
test-map.txt (14.7 KB)
